Cold Air Inductions
Old 07-09-2013, 04:23 PM   #1
jokerkojack
jokerkojack's Avatar
Drives: 2012
RS bulbs don't match each other
Hello, I installed a set of rs head lights I got used here on camaro5. After a few issues I still have one more problem.
I installed the rs headlights on my non rs car. Problem is I can't get the bulbs to match. They have new matching bulbs in them but the drivers is way more powerful. I have made sure they were put in correctly and check to make sure it was the same bulb. I have a harness and its on correct to my knowledge, because it work for a few weeks. I had a water problem with the driver but now have a new unit. Does anyone know why I'm having this issue. Could I have different model units that make the light shine different? Install issue? Power issue? I have sent ofer an email already.
"Madness, as you know, is a lot like gravity, all it takes is a little push."
jokerkojack is offline   Reply With Quote
Old 07-09-2013, 04:35 PM   #2
camaro2lt
camaro2lt's Avatar
can you post a pic?
Old 07-09-2013, 04:36 PM   #3
Rafael205
Rafael205's Avatar
Drives: 2011 Camaro LS
Interesting.. I'm having the same issue..
Rafael205 is offline   Reply With Quote
Old 07-09-2013, 04:49 PM   #4
jokerkojack
Drives: 2012
Kind of different pic during the day.. At night the whole drivers side view is bright and lite up crazy style
Old 07-09-2013, 05:09 PM   #5
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
Bad ballast? Or maybe the bulb is going out? Can u switch bulbs and see if it does the same?
13blackLS is offline   Reply With Quote
Old 07-09-2013, 05:39 PM   #6
camaro2lt
camaro2lt's Avatar
not the ballast.....seems like one side has the brights on and the other is normal
let me ask you..when i sent you the new drivers side was it the same as this?
Old 07-09-2013, 05:40 PM   #7
Rafael205
Rafael205's Avatar
Originally Posted by jokerkojack View Post
Attachment 532392
Wow.. Mine isn't as noticeable.. I have to get a decent distance away at night to be able to notice.
Old 07-09-2013, 05:58 PM   #8
camaro2lt
camaro2lt's Avatar
sounds like you have a bulb issue
Old 07-09-2013, 06:02 PM   #9
jokerkojack
Drives: 2012
The pair I had last week was good. The bulbs matched and I had no issues. You sent me the new one I installed it and now having this issue.
Old 07-09-2013, 06:02 PM   #10
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
Maybe they are not aimed properly??
christianmotox is offline   Reply With Quote
