sjm autoprod
Old 07-09-2013, 05:08 PM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Easiest way to remove the oil pan?
Undo pan bolts, undo motor mounts, lift on engine an inch with no problems?
Old 07-09-2013, 05:15 PM   #2
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
subscribed... although upon re-reading some stuff... it doesn't look good.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 07-09-2013, 05:29 PM   #3
Denis
Denis's Avatar
Drives: 2010 SS
I've never done it. But I assume it couldn't be much more than that.
Old 07-09-2013, 05:31 PM   #4
PQ
Booooosted.
PQ's Avatar
I think you'll be surprised. lol
But I hold out hope.
Old 07-09-2013, 05:34 PM   #5
Denis
Denis's Avatar
Drives: 2010 SS
I hope for your sake its that easy! Let us know. Good luck.
Old 07-09-2013, 06:05 PM   #6
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Cut through bottom brace. Remove pan. re-weld brace?
I think this is a good question for the help desk.. lol.
K32 Camaro is offline   Reply With Quote
Old 07-09-2013, 06:10 PM   #7
thahemp
Geek
thahemp's Avatar
Unfortunately, that's the help desk stance as well . I was hoping someone had some kind of clever suggestion that no one else had thought of yet! I think CGT (or CFD.. always get them confused) made a replacement brace when he yanked his pan out.
You would still have to cut, but you wouldn't have to re-weld.
x = ~x
Old 07-09-2013, 06:13 PM   #8
thahemp
Geek
thahemp's Avatar
Here... this is roughly the point in his thread where he pulls the pan. You might have to go a page back or forward, but you get the idea...
It's CFD, not CGT.
http://www.camaro5.com/forums/showth...=280655&page=8
x = ~x
Old 07-09-2013, 06:28 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If you wanna hack up your car yea cut the k member, me personally Id just pull the whole motor out stop kidding yourself PQ, take the intake off and the valley cover. I have a plate that you use to hoist it up. I can ship to you when your ready.
Old 07-09-2013, 06:31 PM   #10
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
I think his motor is shot.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-09-2013, 06:34 PM   #11
thahemp
Geek
thahemp's Avatar
I disagree. He can be back on top with a little caution here.
x = ~x
Old 07-09-2013, 06:46 PM   #12
thahemp
Geek
thahemp's Avatar
PQ if you have access to a cherry picker this isn't so bad. Use his plate, unbolt the tranny, and pull it out the top. Just wrenching from that point. Not what you're hoping for I know, but it's not such a bad deal. A solid weekend making sure everything is ok, and replacing what needs replaced and you'll sleep sooooo much better in the long run.
x = ~x
Old 07-09-2013, 06:57 PM   #13
PQ
Booooosted.
PQ's Avatar
It's CFD, not CGT.
Sheesh......... what a ****ed up design.
Pump first. I gotta do that anyway. Might as well make it the first thing.
Old 07-09-2013, 07:18 PM   #14
caverman
caverman's Avatar
Drives: '69 SS Convertible
I haven't looked specifically at the 5th Gen Camaro but we just did this to my '69 about a month ago. Maybe it will work on the 5th Gen.
-Put the car in the air
-Undo cat-back from headers
-used a jack with a small piece of wood under the oil pan to help lift motor
-undo motor mounts
-jack up motor as high as you can before transmission hits tunnel or headers hit
-put a small block of wood in between the motor mount and engine
-lower the motor back onto the piece of wood you put on the motor mount
That gave us about 2" or so to work with. It wasn't fun but it worked. There was just enough room to get the pan out and back in. Took a little cussing and extra sweat but we got it. My dad used to do this all day long back in the day but that was back we used the smaller Muncie 4-speed. Now the Tremec 5-speed takes up all the room in the transmission tunnel.
In my case my dip stick got turned some and tangled up in my rotating assembly. It ate up about 6" of the stick and left about 4 pieces of metal and no telling how many shavings I couldn't see.
Build Journal
