HeadlightArmor
Old 07-10-2013, 12:37 PM   #1
jkof08
jkof08's Avatar
Drives: Black 2SS/RS
How Much RWHP would this set up give Me
How Much RWHP could i expect out of the below. Also is My resinator Hurting my power? if so by how much?
2010 Camaro 2SS A6
MODS
Hennessey CAI
Ported Throttle Body
JRE Scoop
Flowmasted Pro Series Axel back
Jannetty Custom Tune
3.70 Gears
Stainless Power Long Tube Headers
High Flow Cats
C.A.I. CAI, FlowMaster Pro Series, 1LE Strut Brace, Ported Throttle Body, Vengeance Tune, JRE Scoop, MSD Wires, 3.70 Gears, Stainless Works LT Headers and Hi Flow Cats, Pro Torque 3500 stall, LS3 Conversion Stage 2 TSP Port & Polished Heads, Kaotik CAM. 18x10 Forgestar F14 wrapped in 305/45/18 MT Street ET II's
12.068 @ 119.9 1.9 60ft (on 20' DR's with a VVT CAM)
jkof08 is offline   Reply With Quote
Old 07-10-2013, 12:38 PM   #2
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
i'm going to guess 60ish rwhp.
Old 07-10-2013, 12:39 PM   #3
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
Yeah 50 to 60 but it will "feel" quicker with the gears you have.
tramtwo is offline   Reply With Quote
Old 07-10-2013, 02:13 PM   #4
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
With those mods. 370-385 on a dynojet. If your base was average. However your sig 1/4 run is pretty slow for being tuned and a CAI unless it was 95 degrees outside with a ton of humidit or your 60ft sucked..
My car made it's maiden passes at SGMP a few years back. I was running 13.3 @107 bone stock with 2.01 60ft with a full tank in Valdosta in 75 degree weather.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 07-10-2013, 04:02 PM   #5
Jims Mongoose
Jim
Jims Mongoose's Avatar
Drives: 2013 Black 2SS 1LE
2010 Camaro 2SS A6
MODS
Hennessey CAI
JRE Scoop
3.70 Gears
High Flow Cats
What is a ported Throttle body? On another thread someone explained to me the polished throttle body, but was is ported?
Thanks
Jim
Jims Mongoose is offline   Reply With Quote
Old 07-10-2013, 04:08 PM   #6
RolltideSS
RolltideSS's Avatar
Drives: 2011 2SS/RS Vert
Ported means they widen the openin to allow greater air flow. It is supposed to increase the throttle response
RolltideSS is offline   Reply With Quote
Old 07-12-2013, 09:01 AM   #7
jkof08
jkof08's Avatar
it was a Diablo Tune so it didnt really make a difference the mods listed above the car is what was on it at the time of the race. so it wasnt tuned or any of the other stuff. and the run was a little over a month ago so it was pretty bad conditions. ive been trying to hit the track but its been raining for the past month. the weather was 95 degrees with 40% humidity.
Old 07-12-2013, 09:21 AM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I say about ~40
TB, axle back, gears, scoop, don't add horsepower.
It's the headers, CAI and tune that do.
Old 07-12-2013, 11:40 AM   #9
Ivan @ Southwest Speed
Thanks
Jim
Finessing the internal flow characteristics of the air coming into the intake manifold. Creates a solid 8-10 rwhp on stock SS cars. They are undoubtedly one of the best mods that you can do on your Camaro.
Simple bolt on, no tune required...good stuff. And the folks at VMax (and us) offer a money back guarantee so that alone should support how great they work for folks.
They aren't going to knock your socks off but you can tell the difference just in everyday driving verses a car that doesn't have one.
Good luck and enjoy!
Old 07-12-2013, 03:16 PM   #10
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
I have to agree that's a low et for a ss nevertheless a ss with mods even untuned with just a cai and lts I hit a 12.79@110 then I added a cam and traction became a huge issue! And only mustard out a 12.4
Nightmare2012 is offline   Reply With Quote
Old 07-12-2013, 03:26 PM   #11
Juice2SS
Drives: 2011 2SS
With those mods, I'd guess around 365-370 at the wheels. CAI, LTs, and tune are the real power adders.
Juice2SS is offline   Reply With Quote
Old 07-12-2013, 04:28 PM   #12
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
My car seemed to be a little on the low side, at least dyno wise. With headers, intake, exhaust, 3.70 gears and a tune, I pulled about 355 whp. I've read that gears can actually lower your dyno readings a little. Anyway, with those mods, I ran 12.8 at 109-ish. That was with a 1.99 sec 60' time, so there was still some left on the table.
Anyway, it seems that on the auto, you can do full bolt-ons and still not hit 400 whp. You'll get close, but not quite there.
E.T. is offline   Reply With Quote
Old 07-12-2013, 04:45 PM   #13
RA1987
RA1987's Avatar
Drives: SS
Stop guessing put in on a dyno.
RA1987 is offline   Reply With Quote
Old 07-13-2013, 03:03 PM   #14
62nalide
62nalide's Avatar
Drives: 2013 SS
Add an UD pulley to that list!
62nalide is offline   Reply With Quote
