Old 07-10-2013, 10:56 PM   #1
adamthedrummer
Drives: 2011 IOM V6 Camaro
Optima Baterry... Don't hate....
Which yellow top Optima battery do I need to put in my 2011 V6 LS ? I was thinking the D27 ??? Any help ???
adamthedrummer is offline   Reply With Quote
Old 07-10-2013, 11:07 PM   #2
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
no hate involved..do a search on the web...there are much better batteries to buy at less money that last longer....read and convince yourself.
Optima switched to a diff mfr plant a few years ago, not the same as they used to be....
google "optima failure"
Glen e is offline   Reply With Quote
Old 07-10-2013, 11:13 PM   #3
adamthedrummer
I read Ur post about that. Do you really think that their value has gone down that much just because of manufacturing location ???
Old 07-10-2013, 11:22 PM   #4
Glen e
Glen e's Avatar
I can name 3 diff marine mfrs that gave up putting them in boats because of failures - Yellowfin, Sea Vee and Intrepid. They now use Odyssey. Odyssey makes a batt for Sears (Die Hard AGM) that is superior to Optima for the same money,.
That being said, unless you are running multiple amps, premium batteries are not really needed in cars....A good interstate, Wal-Mart or Johnson Controls batt will work fine and last. Get as much CCA as you can get. It's the constant sucking the batt down and recharging that kills them. More reserve and the less you pull every day. day. Batts last a long time if they discharge 10-15%, then recharge, rather than 50%...
Old 07-12-2013, 07:22 AM   #5
hworth18
Jus' Cruzin
hworth18's Avatar
Drives: 2017 Camaro 1SS Krypton Green
I agree with Glen e.. I only use Interstate batteries and have never had any problems.
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark
hworth18 is offline   Reply With Quote
