Old 07-10-2013, 11:52 PM   #1
Forsberg112
Forsberg112's Avatar
Drives: 2002 Camaro SS SLP
Night Fury Cam
I wanted to get a few different opinions on the Night Fury Cam. It sounds amazing and the HP gains are great, but I'm curious as to the drive ability for people who have had it for a while. It is always nice to get the cam and it is ok to drive for a while (been there in general), but how about long term? Too loud, too much bucking, etc? I appreciate the opinions, I have a lot of mods ready to go on the car and am ready to pull the trigger on a cam as well and get the tune all at the same time.
2002 Camaro SS SLP
1973 Corvette L48 - Numbers Matching
2014 Z71 Silverado
1966 Jaguar E-Type
Sold -2013 SS/RS M6
Forsberg112 is offline   Reply With Quote
Old 07-11-2013, 03:56 AM   #2
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
DO IT!!! Love mine. Wife loves hers. Neighbor loves hers. Shawn and Nick are great guys and have excellent customer service. Can't go wrong with Lethal. They will be at CamaroFest in a couple of weeks. My car and several others will be there as well if you want a ride or just hear it.
mp51998 is offline   Reply With Quote
Old 07-11-2013, 09:51 PM   #3
lsuguy
lsuguy's Avatar
Drives: 2011 2SS/RS
Install it along with the 3.91s in your signature. It will drive like stock except when you get on the skinny pedal.
lsuguy is offline   Reply With Quote
Old 07-11-2013, 10:51 PM   #4
FurySS
Furious Shine
Drives: None
Well I have an A6 and had to put a 3200 stall in, so I will say except cruising on the highway mine isn't much like stock. . For the mods I had done, my #'s also came in lower than I expected. I am hoping Shawn can look at it while he is here for the Fest. I do love the sound of the cam!
FurySS is offline   Reply With Quote
Old 07-11-2013, 11:24 PM   #5
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Originally Posted by 2010 Indy Pace View Post
Well I have an A6 and had to put a 3200 stall in, so I will say except cruising on the highway mine drives nothing like stock. Mine was installed and tuned by Mike Norris and I periodically have issues with the idle dropping down to 250 then shooting back up to 800-900 (still trying to tweak it). For the mods I had done, my #'s also came in lower than I expected. I am hoping Shawn can look at it while he is here for the Fest. I do love the sound of the cam!
That's a tune issue, not the cam. I have an L99 and if I did the conversion to LS3 i'd get it if Id stay vvt id get Rhino79's biggest cam and a 3600 stall FTW!
Old 07-11-2013, 11:33 PM   #6
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
The cam will buck so be prepared for that. If you change the way you drive youll never notice it. I let the engine slow my car down to save some brake pad so Im more susceptible to the bucking than others may be. It only gets bad under 1400rpm. Cruising a parking lot requires more clutch work or you look like a tard going through the aisles. If I were to it over again, Id go smaller since this is a daily driver. It all depends on what you consider "driveable." Depending on your typical drive to work, your gas mileage will go down. When I lived in TX and drove 30 miles one way to work on the hiway, I averaged 16.8mpg. Now that I live in AZ and see no hiway since I live 6 miles from work, Im only averaging 11.4mpg. Gotta pay to play! Good luck!
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 07-11-2013, 11:38 PM   #7
FurySS
Furious Shine
Drives: None
Oh I completely agree litle88 - nothing wrong with the cam. Just frustrating when you don't see the results you were hoping for. Mike normally puts in a smaller cam (his own grind). I highly respect his knowledge and reputation, just having trouble getting it dialed in. Best I can figure is Shawn does something a bit different in the tune. I was at 460/414 (Night Fury, FAST, Stage 1 heads, UD pulley, Kooks Stepped Headers and Cats, Vigilante 3200). Shawn recommended pulling the FAST off to see if it was losing power. Put stock intake back on and dyno'd 460/412, so the FAST was not doing much. I am hoping to get a ported intake from Shawn to put on.
Old 07-11-2013, 11:46 PM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Oh I completely agree litle88 - nothing wrong with the cam. Just frustrating when you don't see the results you were hoping for. Mike normally puts in a smaller cam (his own grind). I highly respect his knowledge and reputation, just having trouble getting it dialed in. Best I can figure is Shawn does something a bit different in the tune. I was at 460/415 (Night Fury, FAST, Stage 1 heads, UD pulley, Kooks Stepped Headers and Cats, Vigilante 3200). Shawn recommended pulling the FAST off to see if it was losing power. Put stock intake back on and dyno'd 460/412, so the FAST was not doing much. I am hoping to get a ported intake from Shawn to put on.
wow 460 thru a stalled Auto is no PUNK bud! But im sure the guys at Lethal will help you if they can. Were you using a Nw102 Tb? if not I bet you would of gained some! IMHO
Keep me posted let me know what happens with your tune.
Old 07-12-2013, 12:00 AM   #9
Forsberg112
Thanks all, I love the sound and power as I stated, so I will just pull the trigger. I can work through the high rpm issues during slow drive so that should not be an issue.
2002 Camaro SS SLP
2014 Z71 Silverado
1966 Jaguar E-Type
Sold -2013 SS/RS M6
Old 07-12-2013, 12:04 AM   #10
FurySS
Furious Shine
Drives: None
Will do! I'm a semi lurker, I have been watching posts and idle videos for over 6mos knowing Night Fury was what I had to have! Certainly 460 is nothing to sneeze at considering it was 345 with just the CAI & Catback. That is an awesome gain for N/A no question about it. I was thinking maybe I would see 480hp, but the TQ reading lower is what puzzled me and Shawn. I know that no 2 dynos are alike and the stall could be affecting the numbers I suppose. I have ZERO regrets on my cam choice, and Shawn has even talked to Mike on the phone for me. Mike has made some adjustments for me, but I think I'm at the point where I need Shawn's expertise as he has more experience with this cam.
Here are my dynos, the first one is before/after (with the FAST). The 2nd one is with FAST vs. Stock Intake.
Old 07-12-2013, 01:11 AM   #11
Slickcas
Drives: 12' 2SS/RS LS3 IBM
114 rwhp is a huge jump. Also 460 rwhp with your A6 is like 480-490 if it was a M6. I may be wrong but did not think that cam would do much over that. Taking in to account you started at 345rwhp with. CAI.
Please keep us updated. I know Mike Norris is very good with the LS motors.
Slickcas is offline   Reply With Quote
Old 07-12-2013, 07:15 AM   #12
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
This cam is no different to tune than any other one, 460 is about right for an auto car depending on the dyno. Everyone's dyno is going vary some.
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 07-12-2013, 08:43 AM   #13
JEFF75645
Drives: his wife crazy buying mods
460 in a stalled A6 can be quite fun. But bad for tires though.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 07-12-2013, 10:24 AM   #14
FurySS
Furious Shine
Drives: None
Yeah, I think Shawn said with heads they have seen up to 480 with A6, but 460 is definitely in the ballpark. It was the torque he felt was off a bit as they normally see at least 430. If I recall Mike has it around 28-29* timing and 12.5-13 A/F. It was surging and bucking more in the 1200-1500 range while cruising but Mike adjusted the trans and that is better. Really the only issue I am having right now is sitting at a stoplight the idle will just drop from 900 to 250, catch itself and shoot back up. Doesn't do it all the time, but freaks me out thinking it might die lol. But I am pretty sure between Mike & Shawn that will get worked out
Shawn said he would port a stock intake for me and I could maybe see 5-10hp more, so since I sold the FAST I will go that route.
I am still getting used to driving with the stall for sure
