JUICEDMOTORSPORTS
Old 07-12-2013, 09:36 AM   #1
skirush
skirush's Avatar
Drives: 2013 1LS
Plasti-dipped front upper and lower fascia
Just got done plasti-dipping my front fascias. What can I say...the stuff is addicting. I'm a university professor, so that's why I have all the time to do this stuff...summers off
Anyway, sellers on ebay wanted about $60 for the vinyl overlays and you can' fix vinyl after stone chips. My car is a daily driver; unfortunately, I had a lot of rock chips. It was just a matter of time before the vinyl would have been all chipped up. Then it would have looked like crap.
Overall, I'm pretty happy with the end result. Essentially, I achieved the same result as the vinyl without spending $60...and, I can repair the look if/when it gets chipped up. When I need to redo it I'm sure I'll do better job because I'm a little better with taping and spraying now than a few days ago. Taping is a pain. Just like others have said the trick is spraying one really thick coat (evenly of course) and then peeling off the tape immediately to give you a straight line. I think the car looks meaner than before. I'm glad I did it. The front bowtie is off in the after pics because I'm redoing it. I wasn't happy with the result. I want it to look better.
Here's the car yesterday:
Here's the car this morning:
skirush is offline   Reply With Quote
Old 07-12-2013, 10:05 AM   #2
pmandeep
Drives: 2013 VR 2LT/RS
Looking Nice!
2013 Victory Red 2LT/RS
"I don't break rules. I just bend'em - a lot!" -Sideswipe
pmandeep is offline   Reply With Quote
Old 07-12-2013, 11:21 AM   #3
Glen e
Glen e's Avatar
Drives: Garnet 2LT RS
EXCELLENT!!! I'm doing same thing as soon as my splitter gets here - how many coats and does it look uniform? - from here it looks great....
Glen e is online now   Reply With Quote
Old 07-12-2013, 11:38 AM   #4
blkngldbabe
Barossa's handler
blkngldbabe's Avatar
Drives: 2LT/RS RJT
+1 I'm looking to do this. Just bought a case of the spray to do it but I'm skeered!!
SLP's GTA Master Specialty Vehicle and Master Parts Dealer
blkngldbabe is offline   Reply With Quote
Old 07-12-2013, 11:41 AM   #5
skirush
skirush's Avatar
Drives: 2013 1LS
Well...it depends on what part you're talking about. I did the top and the bottom differently. I did the lower first. The lines were pretty much just straight. So, I taped it then applied 5 coats. Then, I hit it with 3 coats of glossifier. We I removed the tape, it came off pretty well on the visible parts, but on the bottom there were 2 tiny parts that are not visible (underneath the car) that were not exactly razor sharp.
The upper fascia would be completely visible so I wanted the line to be really sharp. So, I googled how to make a sharp line with plasti dip and found a vid on their website that said you spray one thick coat and they you have to remove the tape right away to get a real sharp line. Oh...that made sense. I wish I googled it before doing the bottom.
Therefore, the upper part (below the headlights) is one really thick coat. Both look the same though. If anything the top looks better. You can't really tell a difference beween how "deep" or uniform either one looks. The line for the top did come out good. There tip worked well.
Old 07-12-2013, 11:43 AM   #6
skirush
skirush's Avatar
Drives: 2013 1LS
That's funny because I was really scared too. Once you use it, you'll see how easy to use it is...and addicting. I'm actually looking to do my mirrors maybe.
I have Turtle wax bug and tar remover and a microfiber sponge to remove any over spray...it works fantastic. Wipes it right off. So, no reason to be scared.
I hightly recommend using plasti dip over vinyl for these parts.
Old 07-12-2013, 01:05 PM   #7
Glen e
Glen e's Avatar
A person that googles to solve his problem than just asking more questions...refreshing...thanks ....looks clean and since the top is horizontal , I'm sure it'll hold.....plastidip told me how well things hold on the front is how much the surface is prepped...alcohol and acetone wipes for me......
Old 07-12-2013, 02:49 PM   #8
blkngldbabe
Barossa's handler
Drives: 2LT/RS RJT
I did one wheel (my winters lol which are factory as well) just to see how it worked and if I liked it. My honey did the Grille for his Jeep wrangler and we are going to do his fender flares soon. I'm thinking of hood spears and 1LE Hash marks too.
