sjm autoprod
Old 07-12-2013, 11:46 AM   #1
25homes
25homes's Avatar
Drives: 2010 camaro 1ss auto
installing long tube headers?
How hard is this? Do u have to lift engine or not? Also says bolt on no mods neccessarry taking it that means it will work with stock exhaust
25homes is offline   Reply With Quote
Old 07-12-2013, 11:53 AM   #2
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
You do not need to lift the engine. Just make sure you give yourself 2' of clearance underneath the car. With the correct midpipes you can connect to factory exhaust. You will need a tune if you don't want to stare at a CEL light.
Bye bye, Bumblebee!
Old 07-12-2013, 11:54 AM   #3
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
If you have just basic knowledge, it's an easy mod. You don't have to jack up engine, you will need to jack up the car high enough to slide the headers in from the bottom. I have a $40 jack from Oreilly and it was fine. Depending on what brand header you get will determine how they fit. Most top brands will go right in with no issues!
Camarojt is offline   Reply With Quote
Old 07-12-2013, 02:10 PM   #4
25homes
25homes's Avatar
Cool thanks boys...have diablo intune sure this b fine to tune I take it I disable rear o2 sensors?
Old 07-12-2013, 02:40 PM   #5
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Get high flow cats with bungs for the rear O2's, or off road pipes. Pull your spark plugs before you start or you may break some.
Old 07-12-2013, 02:42 PM   #6
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
It's easy to do, just time consuming. If it is your first time doing this, allocate at least 3-4 hours, if you have a buddy and both of you are mechanically capable you could do it a little quicker.
Besides the typical tools, you will also need a O2 sensor wrench (sorry don't know the actual name of it), a torch, a can of PB Blaster (or some other spray that help break loose bolts because getting the O2 sensors out of the factory cat's are a royal pain), and some anti-seize for when you reinstall the sensors.
Old 07-12-2013, 02:49 PM   #7
25homes
25homes's Avatar
Thanks draco my brother and I are both mechanically inclined...brother could strip engine doen to bare block put back together so I think we can handle... when we did buddys TA WS6 it was pain in butt had to lift engine to fit them...
Also do u have to heat wrap? Cant justify buying stainless if ur gonna have to wrap them
Old 07-12-2013, 03:17 PM   #8
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Very straightforward and not hard at all. I recommend you doing it with the help of a buddy just to build your confidence up. Plus when you put the dipstick tube back in (with help), you won't have to make a thread saying "HELP!! I Can't GET THE DIPSTICK TUBE BACK IN" lol.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 07-12-2013, 03:40 PM   #9
Denis
Denis's Avatar
Drives: 2010 SS
It's very easy....surprisingly easy. An extra set of hands is great to have.
Old 07-12-2013, 03:53 PM   #10
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
This. An extra set of hands definitely helps with most exhaust jobs. Just take your time and should be fine.
Old 07-12-2013, 04:03 PM   #11
Camarojt
Camarojt's Avatar
You can borrow an O2 socket from Auto Zone, just buy a small packet of anti-seize and PB blaster, That and warming up the engine got my O2 sensors out with just a grunt! Also get your brother to get under the car with a flashlight when you take the dipstick tube out. Take note of where the hole is so that when you get ready to reinstall it, you can find it again.
You will enjoy it more if you do it yourself!
Old 07-13-2013, 11:43 AM   #12
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Personally I would not wrap the headers. It will destroy the headers over the long term and most manufacturers will not warranty headers that have been wrapped. As large as the Camaro's engine bay is, heat is really not an issue but if you it bothers you, you can always buy coated headers.
Old 07-13-2013, 03:02 PM   #13
25homes
25homes's Avatar
Doesn't bother me I don't want them wrapped... thanks guys...so dipstick is an issue to watch... can anyone explain lil more
Old 07-13-2013, 03:15 PM   #14
matt55
matt55's Avatar
Drives: CTS-V
My o2 socket is a 7/8" wrench..
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
