Emblempros
Old 07-12-2013, 01:20 PM   #1
cybergrey_ss
Drives: 2010 cyber grey camaro SS
zr1 clutch help!
i have a zr1 clutch, where can i get a 6 bolt fly wheel for this clutch so that it will go into my 2010 camaro SS. or will this clutch not work
cybergrey_ss is offline   Reply With Quote
Old 07-12-2013, 01:31 PM   #2
blake-b
blake-b's Avatar
Drives: Black 2010
You are going to need a spacer for the slave cylinder as well. I am running the ZR1 clutch as well and it has worked beautifully so far.
Flywheel:
http://www.lingenfelter.com/mm5/merc...=#.UeA8xW0XnWg
http://store.katechengines.com/ls9x-...heel-p245.aspx
Spacer:
http://www.lingenfelter.com/mm5/merc...6#.UeA83G0XnWg
While you are changing it out, go ahead and replace the pilot bearing unless your car is low mileage.
ADM Performance is a Lingerfelter dealer so if you want to support a forum vendor, go through them.
Old 07-12-2013, 01:34 PM   #3
cybergrey_ss
ok, i bought the ram throwout bearing do i still need the spacer?
Old 07-12-2013, 01:53 PM   #4
blake-b
blake-b's Avatar
Drives: Black 2010
I have no idea about that. You might call Lingenfelter or Katech or Ram and ask. Or perhaps someone will chime in.
Doesn't the Ram need shimming to work anyway?
Old 07-12-2013, 02:06 PM   #5
cybergrey_ss
it comes with shims; i have not done the math side of it figure out how much shimming is needed. thats why i was asking if i really need it or not. thank you for your help
Old 07-12-2013, 02:32 PM   #6
blake-b
blake-b's Avatar
Drives: Black 2010
I am pretty sure the spacer would be too big. I would call Ram and ask for dimensional specs and compare them to a stock slave. That will give you an idea. I think it will work once the proper shim depth is figured out.
