R1 Concepts
Old 07-13-2013, 12:38 PM   #1
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
Slave Cyl, throwout bearing question
I've lost my second slave cylinder and was wondering if the ZL1 setup will fit the SS TR6060 without issues? Or does anyone have a better solution? Clutch is a Mcleod RXT and car is putting down 660rwhp.
Thanks, any advice would be appreciated.
gnturboray is offline   Reply With Quote
Old 07-13-2013, 01:05 PM   #2
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
subscribed...
I have the same clutch and have had no problems with the slave. But was curious on any ugprade options that are out there. also any other alternatives for a master too.
Best of luck man!
xjer22x is offline   Reply With Quote
Old 07-13-2013, 02:03 PM   #3
H-E
Drives: 2010 zr1 Camaro 2011 vert
We do not use clamp load to hold your car with the Street Slayer,that is the issue with alot of whats out there. I can promise you the Street Slayer will do everything you hope for with no guess work .We feel the Street Slayer is the best value to be had when you factor in the long wear life and the ability to be rebuilt nothing comes close. If we can help you out in any way give us a call
H-E is offline   Reply With Quote
Old 07-13-2013, 02:44 PM   #4
gnturboray
gnturboray's Avatar
Not looking for a new clutch,,,,
Old 07-13-2013, 02:59 PM   #5
Jc's1LE
Drives: 2015 SW 1LE BA NPP Recaros
I have a 1LE 3 months old with 1k miles and I think the slave cyl and brake booster are the same if so im on my 2nd one and they are doing some other parts know I will know better Monday or Tues GM said not to put the oem one back in they were sending some other parts
Jc's1LE is offline   Reply With Quote
Old 07-13-2013, 03:01 PM   #6
gnturboray
gnturboray's Avatar
The slave cyl and throwout bearing are one unit
Old 07-13-2013, 08:04 PM   #7
H-E
Sorry when you asked about a different setup ,zl1 i thought you were looking for a replacement clutch.....I dont think the slave is a problem we use the stock slaves even with our triples.. I hope you get it figured out
Old 07-15-2013, 09:51 AM   #8
Jason P
Jason P's Avatar
Drives: 2011 2ss
Ram clutch makes a nice slave cylinder.
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
Jason P is offline   Reply With Quote
