sjm autoprod
Old 08-18-2013, 02:18 PM   #197
J_Vibe92
J_Vibe92's Avatar
Drives: 2013 Mustang 5.0
this is making me sad cause of all the issues :( i wanted a IPF too
Performance Mods: Vararam Intake, MRTv2.0 exhaust, Elite Engineering CC, Vmax Black Iceolator, Vmax Ported TB, OBX LT Headers w/ no CATS, LMR Tune
Visual mods: Eagle Eyes w/5k hids, Custom Hood Spears, Heritage Grille, Stage 2 LED Dome lights,Transformer Emblems, PD Bezels, 19in Chevy rims with pirellis, Blue painted calipers, GM GFX Front Splitter, 35/20 % Tint, TailLight Tint(charcoal)
1/4 Mile: 13.65 sec @ 102.53 mph R.I.P.
J_Vibe92 is offline   Reply With Quote
Old 08-18-2013, 02:29 PM   #198
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Mine ran great before the intake manifold came apart and misfired like crazy, then it was problems.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 08-18-2013, 02:34 PM   #199
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Originally Posted by MagnumForceGB View Post
Well, took it for a test drive this morning, I can tell some back pressure is missing down low but other than that the car is not that different, just a hair louder and higher pitch. I can't tell if the car is hesitating right now, seems like every little noise is causing me to go "WTF is wrong now?".
I'm going to remove my boost gauge and the car will be back to the same way it was when I first installed the kit just minus the cats. Will keep driving it and see how it acts.
Since I gutted my cats, can I use one of my rear bungholes (giggity) for a wideband sensor and just cap off the connector?
I feel for you... the joys of owning a modded car! Only thing that makes that worse is when you are a thousand miles from home!
scrming is offline   Reply With Quote
Old 08-18-2013, 02:55 PM   #200
J_Vibe92
J_Vibe92's Avatar
when is the mustang getting a procharger
Old 08-18-2013, 03:47 PM   #201
MagnumForceGB
Saving up for it now, but if problems keep happening it will be a long time. Thankfully the Mustang can be dyno tuned unlike this POS that Chevy decided to use.
Old 08-18-2013, 04:32 PM   #202
J_Vibe92
J_Vibe92's Avatar
I thought ipf had it down
Old 08-18-2013, 06:09 PM   #203
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Have you emailed Arno or IPF about it? If its the tune they have been really fast turning a tune around.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 08-18-2013, 07:25 PM   #204
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Sucks to see your cats basically collapsed. How did you go about gutting them if you don't mind me asking?
Proud owner of litho #179 Click Picture for Build Thread
Old 08-18-2013, 08:36 PM   #205
MagnumForceGB
Yeah, need to do a dyno first and send the results to them.
Pounded it with a very long rod to remove the center of it, then used a small crow bar to peel the rest out to the center and push them out. Took a long time to do the first one, the second one was faster since I learned tricks from the first one.
Old 08-18-2013, 09:19 PM   #206
KMPrenger
KMPrenger's Avatar
Don't let this scare you. IPF has a great track record and I still feel that nobody knows the ECM like they do.
But when you are trying to do remote tuning its pretty much a given that the tune is not going to be as nailed down as it could be if you were doing dyno tuning with a proper wideband.
Old 08-19-2013, 11:24 AM   #207
MagnumForceGB
The car barely pops but there is hesitation still. Might be getting a spark blow out now, going to switch back to my autolites but I have the gap set to 0.035". Reading the autolite plugs off my car the plug temp is correct, the discoloration is right at the bend, but I think the gap was off and the plugged cats didn't help.
Old 08-19-2013, 02:10 PM   #208
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
So what is AFR reading at the 4000 RPM and higher? Any chances your leaning out?
Old 08-19-2013, 02:20 PM   #209
MagnumForceGB
No clue, haven't done a dyno yet and I don't have a wideband. I asked earlier if I could put a wideband in one of the rear o2 sensor ports instead of welding into my headers.
I had too much break at once, the manifold and the cats. Plugs are probably worn from overheating, which would explain being fine the first day but getting worse except during certain conditions.
IPF guys are doing their best to help, should be good soon.
Old 08-19-2013, 02:26 PM   #210
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
BTW Baylor, my wife loves your signature, she is a Texan also and she hates OU.
haha actually it's an inside joke. As I was getting this sig made PQ (an OU fan) said I needed to have the OU logo on my sig and someone else said it needed to say "sucks" on it. So that's why it has "OU Sucks" on my sig. I actually don't mind OU. I just dislike Texas A&M
Aftermarket from American Racing Headers. Either they couldn't handle boost or they got messed up from a misfire and are getting worse.
I had American Racing Long Tube Headers & High Flow cats for about 2.5 - 3 years and during that time one year was super charged. Never had an issue. However, I've heard people with after market cats having issues similar to yours.
Good Luck with everything! Believe me, I feel your pain about having a bunch of issues with your super charged V6.
BaylorCamaro is offline   Reply With Quote
