Old 08-20-2013, 11:02 PM   #225
KMPrenger
KMPrenger's Avatar
Originally Posted by MagnumForceGB View Post
She forgot to turn off traction control...
lol...oops!
I say spin those suckers for another couple seconds! Of course...I'm not paying for your tires either
Old 08-21-2013, 12:42 AM   #226
J_Vibe92
J_Vibe92's Avatar
Drives: 2013 Mustang 5.0
i spin mine for like 5 secs haha. my tires last so long though.
question do yall spin in 1st only or put it in 2nd to get a higher mph and better spin
Performance Mods: Vararam Intake, MRTv2.0 exhaust, Elite Engineering CC, Vmax Black Iceolator, Vmax Ported TB, OBX LT Headers w/ no CATS, LMR Tune
Visual mods: Eagle Eyes w/5k hids, Custom Hood Spears, Heritage Grille, Stage 2 LED Dome lights,Transformer Emblems, PD Bezels, 19in Chevy rims with pirellis, Blue painted calipers, GM GFX Front Splitter, 35/20 % Tint, TailLight Tint(charcoal)
1/4 Mile: 13.65 sec @ 102.53 mph R.I.P.
J_Vibe92 is offline   Reply With Quote
Old 08-21-2013, 09:33 AM   #227
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Next will be IPf bead locks for the tires. lol
Old 08-21-2013, 10:10 AM   #228
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Had 15 misfires on cylinder 6 this morning, and only 6. Not bad enough to go into limp mode.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is online now   Reply With Quote
Old 08-21-2013, 10:26 AM   #229
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
What are you tracking the misfires with ? Obd data stream ?
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 08-21-2013, 10:59 AM   #230
MagnumForceGB
Torque app. Also heard the misfire, sounds like a rumble strip. Its happening at over 6k rpm's.
Old 08-21-2013, 01:57 PM   #231
KMPrenger
KMPrenger's Avatar
I'm guessing this was due to what you posted in the other thread about the filling in your ported intake coming out AGAIN???
Man...I'm beginning to worry that you've had small bits of that stuff run through your engine and maybe that could be causing some of your headaches. Is that possible?
Old 08-21-2013, 05:09 PM   #232
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
No clue, haven't done a dyno yet and I don't have a wideband. I asked earlier if I could put a wideband in one of the rear o2 sensor ports instead of welding into my headers.
I had too much break at once, the manifold and the cats. Plugs are probably worn from overheating, which would explain being fine the first day but getting worse except during certain conditions.
IPF guys are doing their best to help, should be good soon.
To my knowledge, if it's anything like the ls3, it should be fine to run a wide band in the rear. The fueling is adjusted off of the front o2 sensor. If they haven't already disabled the rear o2 codes, The cel will be thrown because it will think the cats are inefficient, but it shouldn't effect how it runs. Not sure if the LLT is like the ls3, but in the ls3 bank 1 (drivers side) runs the Leanest, so you would want the wide band on that side.
Are you taking logs or anything to send to the tuner? Ported manifold problems aside, you really should invest in a wide band.
Jason@ is offline   Reply With Quote
Old 08-21-2013, 05:35 PM   #233
MagnumForceGB
IPF doesn't do datalogging. I want to get a wideband, but I don't trust the exhaust shops around here.
Old 08-21-2013, 05:39 PM   #234
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Why? Welding a bung for the wideband is super easy
Old 08-21-2013, 06:16 PM   #235
MagnumForceGB
I sucked at welding in high school, and the shops around here charge way too much. I was quoted $520 to replace the 2.73's on the Mustang with 3.73's for labor only. I know jegs sells some kind of adaptor that you drill into the pipe and install a gasket to hold the sensor in place, don't know how much it would leak though.
Old 08-21-2013, 07:26 PM   #236
MagnumForceGB
This is what I was thinking about:
http://www.jegs.com/i/AEM/017/30-235...ductId=1334708
Old 08-22-2013, 10:40 AM   #237
MagnumForceGB
Still having popping with 0.030" gap and my torque app said I had misfires on 1,2,6. Going to 0.025" gap tonight.
Ordered a autometer cobalt wideband kit last night also.
Old 08-22-2013, 02:32 PM   #238
Nutbutt
Nutbutt's Avatar
When is the popping ? During accel or decel when you let off of the accelerator ?
