HeadlightArmor
Old 08-22-2013, 02:46 PM   #239
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
During acceleration, pops and hesitates like a blow out. Driving back to work cylinders 1, 3, 6 had misifires. Its higher range so the spark gap is almost there. I'm using iridium plugs.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 08-22-2013, 03:40 PM   #240
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Did you try to swap the coils around? #6 for #1, see if it is putting out the voltage
Old 08-22-2013, 06:29 PM   #241
MagnumForceGB
Here is what my Torque app is saying after I get to 6k rpm's. The AFR(m) is for when I'm hooked into the Mustang since they get a wideband built into their cars (hint hint Chevy).
Old 08-22-2013, 11:04 PM   #242
KMPrenger
KMPrenger's Avatar
The Mustangs have a built in wideband? Aww geez. That'd make tuning a breeze even for these "mail order" tunes.
I'm jealous.
Old 08-23-2013, 06:09 AM   #243
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
I'm jealous.
Yep! And it does!
Ford has been putting in widebands for a while... even our 2011 Flex has a stock wideband! It actually allows the cars to become "Self-Tuning" to a degree! So, yes, makes things a lot easier!
scrming is offline   Reply With Quote
Old 08-23-2013, 09:59 AM   #244
MagnumForceGB
Still popping even at 0.025 gap. Going to 0.031 gap and see if hex vents will cool off the coil plugs enough they will work all the time. Next will be an aftermarket coil, but who the hell makes them? I know the Mustang V6 has aftermarket ones, don't know if they would work on my car though.
Old 08-23-2013, 10:07 AM   #245
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
Where are the misfire counters on the torrque app. I haven't seen those.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 08-23-2013, 10:17 AM   #246
MagnumForceGB
Add a display, then under misfire cylinder #. You need to add the GM specific monitors, which is under settings. Go to manage extra PID, then add a predefined set.
Old 08-24-2013, 10:14 AM   #247
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I'm still waiting on aftermarket coils myself
Old 08-26-2013, 04:41 PM   #248
MagnumForceGB
Got my hex vents installed, look damn good on cyber gray metallic stripes. I can actually open the hood and not get 3rd degree burns now from the heat coming out of the engine bay.
Still having problems with popping and hesitation over 5000 RPM's. The autolites I think are shot, I probably destroyed the iridium tip when regapping them. Going to put the stocks back on and order some Denso ITV22's that come pre-gapped.
Also got my AFR gauge and pillar pod, about to install them, will post pictures later.
Old 08-26-2013, 05:43 PM   #249
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 Camaro 2SS & 16 Suburban LT
So over all this hasn't been an issue with the SC, but a trail of issues since the problems with the IM?
Sledgehammer70 is offline   Reply With Quote
Old 08-26-2013, 07:41 PM   #250
MagnumForceGB
Maybe, but I think I need a tune for my area, its not perfect.
Old 08-26-2013, 07:41 PM   #251
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
you mean like dropping chunks of epoxy down the intake?
Old 08-26-2013, 07:58 PM   #252
MagnumForceGB
That helps seal the engine better, just like installing pistons upside down.
