sjm autoprod
Old 08-28-2013, 01:27 PM   #267
BlwnSS
i like carz
Drives: 99 Formula,85 Trans Am,04 Monte
maybe its time to take it to a shop . something doesnt seem right after all these issues.
I know how supercharging goes , it can be a pita but keep with it.
BlwnSS is offline   Reply With Quote
Old 08-28-2013, 01:30 PM   #268
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Originally Posted by sycraft View Post
11.9 to 12.1 is perfect
Your talking about at WOT right?
And Magnunm do you by any chance of how you wired and installed the gauge and wide band sensor?
Proud owner of litho #179 Click Picture for Build Thread
Old 08-28-2013, 02:26 PM   #269
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
I don't trust the shops around here, plus my problems came from an intake manifold coming apart. I talked to Andy and he agreed that I'm running rich, I may have a boost leak. I think its on the intercooler connection, but I don't want to take the front bumper off if I don't have to.
For the gauges, the wideband comes with its own sensor, you just have to run a wire from the ignition to the gauge. Both gauges need to have power from the instrument lighting, which I T-tapped from the purple wire on the purple plug under the dash.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 08-28-2013, 03:09 PM   #270
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I had the problem is too rich, Arno gave me a better tune. but I already had a dyno that is where i saw the air fuel was off the scale rich. dynoed at 345 hp. never went back to see what is got with this new tune. Cleaning the tips once every three weeks verses once every three days. I should have known better.
Old 08-28-2013, 10:06 PM   #271
Vader2011v6
Vader2011v6's Avatar
Drives: 2014 custom blue ZL1
I spoke with Arno a few weeks back after doing a data log. My afr was 11-12.5. He said it was good. Car runs smooth but haven't had a chance to take it back to the track. This is my 2nd tune since I got my system. Wish there was a way to bridge the gap just a little more with my afr.
Custom blue 2014 ZL1. Cold air intake,clear bra,apex springs,apex oil catchcan,18 percent pulley,stainless works long tubes wit high flow cats,ls3 throttle body, (595tq/607hp) to the wheels
Vader2011v6 is offline   Reply With Quote
Old 08-29-2013, 12:27 PM   #272
MagnumForceGB
I managed to change out the clamp on the intercooler that held the hose from it to the throttle body. The worm gear on that one was stripped, replaced it and the hose is on there tight.
Not going to do any more troubleshooting or racing until I get my intake manifold back, should be getting it next week some time, then I can do some painting.
Old 08-29-2013, 01:40 PM   #273
KMPrenger
KMPrenger's Avatar
As always, best of luck. Really hope you have that car running perfect when the cooler temps come and hopefully you can nab yourself some good times.
Old 08-29-2013, 10:02 PM   #274
MagnumForceGB
Thanks, with this wideband I can see what the engine is doing now and better diagnose the problem. Right now I'm running 10 AFR at WOT, when the exhaust pops and hesitates it goes to 11 AFR, so the spark is not happening. Going to order some Denso ITV22's, supposed to be pre-gapped. I probably tried to re-gap the Autolites so many times that I destroyed the Iridium tip. The stock spark plugs are in the car right now and sometimes I will get full power and the AFR will be at 10.5 to 11, other times it will be 10 then jump to 11 or higher. One thing that pisses me off is that I can buy aftermarket coil packs for my wife's Mustang, but the Camaro gets nothing.
Once I get my ported IM back, I'm going to put the Ice-olator and Plenum spacer back on, get everything painted and start looking at the fuel trims then. I've read that I should be near 11.8 AFR for a good balance between power and safety. Maybe though once I get the intake back that it will provide better airflow and raise my AFR.
Money is starting to be stashed away for the Procharger for the Mustang. Promised my wife she will get one for her graduation gift from college.
Old 08-31-2013, 03:46 AM   #275
Danny_Harris
Drives: no
Originally Posted by Nutbutt View Post
Looking good, I can see another FI permagrin on the horizon
Welcome Dude! there is a burden of information on these IPF frameworks here, If you need anything or have any inquiries, shoot them to us, one of us most likely has a reply. Let the fun start.
Danny_Harris is offline   Reply With Quote
Old 08-31-2013, 07:49 AM   #276
sycraft
COTW 5/06/2013
sycraft's Avatar
Did you know that nutt has the first IPF convertable?
Old 08-31-2013, 10:39 AM   #277
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
Already experiencing the IPF SC permagrin, in fact I'm going to go out for a little run before the rain moves in today ! Top down
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 08-31-2013, 04:45 PM   #278
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Traction control should be on while you drive in the rain, enjoy
Old 09-02-2013, 01:08 PM   #279
MagnumForceGB
Painted the throttle body, intake manifold, ignition coils, and the positive post cover. Wrapped the red wires with Russell wire wrap to make it look better in the engine bay. Now I just need to get the AFR fixed so she will have the go to go with the show.
Old 09-02-2013, 01:12 PM   #280
menendez1293
Question. Is the clear starting to go on your plenum? Seems like some of my paint on my throttle body is starting to fade a little under a 100 miles and 3months.
