Gen5DIY
Old 09-02-2013, 01:15 PM   #281
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Originally Posted by MagnumForceGB View Post
Painted the throttle body, intake manifold, ignition coils, and the positive post cover. Wrapped the red wires with Russell wire wrap to make it look better in the engine bay. Now I just need to get the AFR fixed so she will have the go to go with the show.
Wow, this looks really really good!
Old 09-02-2013, 01:18 PM   #282
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Is that your ported IM?
And when do you sleep? I got mine back from the powder coater- it's still sitting on the bench though...
Agree it is looking really good too! That green looks better to me every time I see it.
Old 09-02-2013, 01:24 PM   #283
Ventmaster
Ventmaster's Avatar
Meant to post a pic-
Old 09-02-2013, 01:31 PM   #284
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Originally Posted by menendez1293 View Post
Question. Is the clear starting to go on your plenum? Seems like some of my paint on my throttle body is starting to fade a little under a 100 miles and 3months.
I thought I had used an engine primer on the plenum cover but I didn't, so it will have to be repainted soon. Everything else but the valve covers are painted with 500 degree paint, with primer and clear coats with 2000 degree paint. The only problem I've had with paint is the driver side valve cover, the paint blistered from the extreme heat.
Its my stock intake manifold, MACE still has my ported one. Painted with dupli-color gloss black.
I never sleep, sleep is for the weak and the Marines. GO AIR FORCE!!!
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 09-02-2013, 01:35 PM   #285
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
I used a self etching primer and the paint and clear are all rust oleum engine enamel. I find it kind of strange that something that is meant for engines can be fading so quickly on the TB. Guess time will tell how well it will last. If it fades I will either repaint or get it powder coated.
Proud owner of litho #179 Click Picture for Build Thread
Old 09-02-2013, 01:43 PM   #286
MagnumForceGB
Dunno why it would be fading so fast, how many coats did you use?
Also Vent, your IM looks good. About the only good thing the LLT has over the LFX, we can paint our IM.
Old 09-02-2013, 01:45 PM   #287
menendez1293
For about each piece I have about 2-3 coats of primer and 2-3 costs of paint with the last being thicker and then another 1-2 coats of clear. My fuse box that was done with normal non height paint still looks perfect
Old 09-02-2013, 02:09 PM   #288
KMPrenger
KMPrenger's Avatar
Looks Amazing!
Old 09-02-2013, 06:02 PM   #289
Ventmaster
Ventmaster's Avatar
Thanks- my first effort was truly ugly (tried to match the IBM). The paint chipped really easy. Decided to go Day-glo for the second try- WTH!
Old 09-02-2013, 07:21 PM   #290
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Makes you want to leave the hood off, looks good
Old 09-03-2013, 08:45 PM   #291
MagnumForceGB
Talked to Arno and got a new tune. I did a WOT in 2nd gear and memorized the RPM's and AFR and told him, he got me a new tune back within an hour and I got it loaded in the car. Took a quick test drive and it feels good, but I need to see how it does after the LTFT's are settled.
Arno also said that all tunes have the rear o2 sensors disabled, something about the sensor getting too hot from the supercharger.
Old 09-04-2013, 04:10 AM   #292
Vader2011v6
Vader2011v6's Avatar
Drives: 2014 custom blue ZL1
It will be nice to see the improvements.When do you think your car will make it back to the track?
Custom blue 2014 ZL1. Cold air intake,clear bra,apex springs,apex oil catchcan,18 percent pulley,stainless works long tubes wit high flow cats,ls3 throttle body, (595tq/607hp) to the wheels
Vader2011v6 is offline   Reply With Quote
Old 09-04-2013, 09:30 AM   #293
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
The tune master strikes again, does he get any sleep?
Old 09-04-2013, 11:12 AM   #294
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
The hours he keeps make me wonder if he ever sleeps !
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
