Solo Performance
Old 07-15-2013, 12:02 PM   #1
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 Mosaic Black Metallic ZL1
Trick to removing cable from LSA throttle bottle?
I know this is probably a dumb question, but I'm going to ask anyway. Is there a trick to removing the cable from the LSA throttle body? I know when I swapped TBs on my 2SS I just pulled the cable out. It doesn't look like that will work with the LSA cable. I have a ported TB coming from Tampa Tuning and just want to make sure I know all the ins and outs before making the swap.
Thanks for your help.
hawk02 is offline   Reply With Quote
Old 07-15-2013, 12:32 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
it is really simple...just a plug to squeeze and it pops right off...more like a wiring harness and no throttle "cable" as almost all cars are drive by wire
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 07-15-2013, 12:44 PM   #3
hawk02
Coupe Newbie
hawk02's Avatar
Thanks for the help! I squeezed the top and bottom end of the plug (close to where the wires go in) and it pulled right out.
Old 07-15-2013, 01:42 PM   #4
Ricardo@Phastek
Ricardo@Phastek's Avatar
Drives: the boss nuts....
Send a message via AIM to Ricardo@Phastek Send a message via Yahoo to Ricardo@Phastek
x2
It is a very simple process, move intake out of the way to access some bolts. Remove 4 bolts and connector. Then just reverse order to put the new one on and tighten the bolts to 89 in.lbs.
Ricardo@Phastek is offline   Reply With Quote
Old 07-15-2013, 02:06 PM   #5
hawk02
Coupe Newbie
hawk02's Avatar
Originally Posted by Ricardo@Phastek View Post
x2
Thank you! You answered my next question on the torque spec for the bolts.
Old 07-15-2013, 05:14 PM   #6
babigguy
babigguy's Avatar
Drives: 2017 ZL1, 2015 Z51 vette 2005 gto
Let us know how the new tb works out!!!!
babigguy is offline   Reply With Quote
Old 07-15-2013, 08:31 PM   #7
hawk02
Coupe Newbie
hawk02's Avatar
I can definitely feel an increase in throttle response and low end torque. I feel a little more "pinned back in the seat" in first and second gear now. Temps here today are in the 90s with humidity hovering around 100% so not the most ideal conditions. But even with the less than ideal temps the increases from the ported TB were very noticeable.
Only other mod I have is an Elite catch can which I installed at 200 miles. I now have over 1800 miles on the car. When I took the TB off today and looked inside the intake manifold, it was clean as a whistle. I saw no traces of oil anywhere. That made me feel good.
All in all, I'd have to say the ported TB and catch can have both been worthwhile mods. And the customer service I received from Tampa Tuning has been beyond excellent.
Old 07-15-2013, 09:07 PM   #8
babigguy
babigguy's Avatar
did you go with the 87 or the 90 mm tb ?
Old 07-16-2013, 12:00 AM   #9
hawk02
Coupe Newbie
hawk02's Avatar
I went with the 87 because no tune is needed. It's just a 1 for 1 swap.
