BeckyD @ James Martin Chevy
Old 07-18-2013, 01:16 PM   #15
NYJets77
Drives: 2013 2LT/RS Summit White
While it probably doesn't have a huge impact on air temp since it's such a small area of the intake manifold, it certainly can't hurt to get it off of the engine.
I have a question about this. Having moved from a 2011 LLT to a 2013 LFX, It seems the engine compartment is way hotter and for longer on the LFX. Anyone know if this is true, and by how much? And if it is true, wouldn't that drive up the temp of the lower IM?
NYJets77 is offline   Reply With Quote
Old 07-19-2013, 07:46 PM   #16
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
I really can't say myself as I haven't had the chance to play with a 2010-11 LLT car... If it is true, I would doubt that the ambient air in the engine compartment would have a big effect on the lower portion of the intake as it's sitting on the engine and the engine is probably way hotter than the air (that's hopefully circulating from movement) around it.
I have scheduled dyno time for the 3rd, I will be testing the stock LFX manifold by itself, the LFX manifold w/ a 1" Extendolator, and If you haven't been following the Adaptolator thread in the LLT section, I have successfully mounted and am currently running an LLT intake manifold on the LFX engine via The Adaptolator. I will also by dyno testing that.
Also, if you guys REALLY wanted, I could make a 2nd piece (optional) to the Extendolator that would replace the aluminum lower intake manifold piece of the LFX intake setup.
Jason@ is offline   Reply With Quote
Old 07-24-2013, 02:14 PM   #17
jbrantner24
Drives: 2013 Camaro LS M6
I would imagine that it will be pretty close to this?
http://www.maceengineering.com.au/ep...Products/MI628
K&N intake, Resonated X-pipe w/muffler delete, Trifecta Tune, rashes up sport muscle tachs.
jbrantner24 is offline   Reply With Quote
Old 07-24-2013, 02:30 PM   #18
Jason@
Huh, that's new... Yup, the 1/2" ones are probably very similar to that... A little more than I was planning to charge. Oh well...
I got the batch of 1/2" ones cut yesterday, I made a few changes. Made the port holes matched to the Ports, rather than the gasket. They also have provisions to actually fit the gaskets, so you won't have to cut the alignment cones, or sand the nubs off the bottom of the gaskets if you wish to use 2 gaskets for the install. Pics later today.
Old 07-24-2013, 06:41 PM   #19
KMPrenger
KMPrenger's Avatar
Wow that is new.
I can't believe that MACE isn't on here promoting them....they are still a vendor aren't they?
If I had an LFX, I'd be all over it....assuming it works successfully like the LLT version does.
Old 07-24-2013, 06:44 PM   #20
KMPrenger
KMPrenger's Avatar
Got this thought after my last post, but I hope someone on here has a stock or very near stock LFX dyno, and then does intake, cats, exhaust, ported LFX intake, and insulator on their car with a CUSTOM tune (like from FSP).
I'm thinking it would beat a fully bolted on LLT with headers and that would be awesome. 360 - 370 HP LFX perhaps?
Old 07-24-2013, 06:49 PM   #21
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 07-24-2013, 07:37 PM   #22
911medic
911medic's Avatar
Are their prices in Australian dollars?
Old 07-24-2013, 08:07 PM   #23
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Hope that's a mistake because it does have a $ sign and last I check that means US currency. If it's right and they are 150 thats a little steep
Proud owner of litho #179 Click Picture for Build Thread
Old 07-24-2013, 08:24 PM   #24
Jason@
That's about the going rate for these... The Vmax LLT ICEolator is $150, and it's only 3/8" thick. At least on the LLT these "isolators" show quite a nice gain for the money, no one has any "proven" numbers yet for the LFX that I can find, only speculation.
Originally Posted by KMPrenger View Post
Wow that is new.
It appears that they are not a current vendor of Camaro5... Upon digging a little deeper it seems they have listed both the isolator "to suit" the VE Commodore LLT, and the Camaro LLT separately... Not sure why, none of my business really... I would assume it is the same part? Perhaps they don't have one "to suit" the Camaro LFX yet??
Would be nice if someone did... Personally, I'll go as far as I can without a tune before it's absolutely necessary. I will have the bone-stock dyno on the 3rd, along with the others I've mentioned... In the near future, I'll basically everything but a tune, as long as it appears to stay on the safe side, but as of yet, I have not installed my wide band on the car, but I will before I think I'm getting too crazy.
Old 07-24-2013, 10:00 PM   #25
Airmaster
Go Gators!
Airmaster's Avatar
Drives: '13 Camaro '12 Abarth '97 Wrangler
Just a quick question, have you gotten back to the PMs yet? Have you already found enough volunteers?
Airmaster is offline   Reply With Quote
Old 07-24-2013, 10:37 PM   #26
Jason@
Yes, I have 2 people that will be testing the 1/2", and 2 that will be testing the 1"
Old 07-24-2013, 11:04 PM   #27
Airmaster
Go Gators!
Airmaster's Avatar
Darn, I PM'd you the day this thread was made, guess I was too late :/
Old 07-25-2013, 01:41 AM   #28
Jason@
Couple pics of the current setup.
