Old 07-16-2013, 07:42 AM   #1
camaroboy1985
camaroboy1985's Avatar
Drives: camaro ss rs 2010 6.2 432 hp
Unhappy transmission clutch problem camaro ss 2010
hi im so getting sick of my camaro ss 2010 in no one knows whats the wrong with it in sweden i just know gm is recalled all camaro ss 2010 s but just in usa i think, i must know the secret issue to fix my camaro ss 2010 clutch! my workshop tried to fix it 4-5 times but after 3-4 months later the clutch is sitting on the floor again! so if someone knows whats the secret issue that gm not tell with the transmissions on camaro ss 2010s please let me know if u know how to fix it please help me
camaroboy1985 is offline   Reply With Quote
Old 07-16-2013, 08:20 AM   #2
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
If you want your car to shift properly, get a separate clutch reservoir and a Hendrix street slayer clutch. Life will be good after that.
Hannibal is offline   Reply With Quote
Old 07-16-2013, 08:26 AM   #3
camaroboy1985
r u sure its the problem? secret issue ? where can i buy it? thanks for answer
Old 07-16-2013, 02:27 PM   #4
Hannibal
Hannibal's Avatar
Hendrix Engineering: http://w.ivenue.com/hendrixengineeri...-clutches.html
Separate clutch reservoir: http://www.camaro5.com/forums/showthread.php?t=236850
No, I'm not certain because I can't see your car. I'm going on what you're reporting. It is well known that the stock clutches in these cars is garbage. It also sounds like the shop you're using is not qualified to work on your car.
Find a new shop. Install the above items. I would bet things will be fine after that.
Old 07-16-2013, 05:40 PM   #5
camaroboy1985
thanks u i will check it
2010 2ss, camaro ss, clutch problems, transmission failure
