BORLA
Old 07-16-2013, 08:38 AM   #1
Astoc
Astoc's Avatar
Drives: 2011 Evo X
SOLD: Forgestar CF5V gloss black 19x10, 19x11, brand new, PRICE DROP!
What I have for sale is a set of Forgestar CF5V wheels for the 5th gen Camaro. I ordered them from Jurrian at ModBargains.com. In the time that it took me to get these wheels, I sold my car. Thus, these wheels are brand new. I received them on July 12.
The sizes are 19x10 for the front and 19x11 for the rear. The wheels were ordered in gloss black. The offsets were selected for the purpose of fitting 295/30-19 tires in the front and 305/30-19 tires in the rear. The CF5V is supposedly the lightest 19" wheel that Forgestar currently offers.
Forgestar advertises a 6-8 week lead time for their wheels, and the wait often extends beyond that due to powder coating quality checks. My wheels took about 10 weeks to receive. If someone were to purchase these, they could have them within mere days.
As these are brand new, I am asking $1,375 shipped.
UPDATE: I received a request for the weight of the 19x10 wheel and decided to oblige. I removed one 19x10 wheel from its package and weighed it. There was still a small amount of protective plastic that I did not want to remove, so subtract another 0.1lbs, maybe. Then again, you would also have to add a tiny amount for the center caps, which are included along with hub rings. The pictures are below.
UPDATE:
A board member contacted me with some concerns about the front wheels supposedly being +35 offset. He stated that the ZL1 front offsets are +23 for 20x10, and an offset of +35 might not clear the OEM shocks with a 295/35-19 tire. I felt that this warranted some investigation on my part.
So, here's a bit of explanation and some interesting information that I just found out:
When I ordered these wheels, I requested offsets that would allow me to fit 295/35-19 tires in the front on a 19x10 wheel.
Later on, after I received the wheels and went to sell them, I sent an email to Jurrian asking him what offsets were chosen for the wheels. Potential buyers had been asking me what the offsets were, and I wanted to be able to give them an answer. Jurrian replied that the wheels were probably no different than the usual, which is +35 front and +39 rear.
Now, I just took one of the 19x10 wheels out of the box and began measuring the wheel. Here's what I found:
  • From the outside of the outer lip to the outside of the inner lip is 275mm (10.82").
  • From the inside of the outer lip to the inside of the inner lip is 254mm (10.00").
  • From the inside of the outer lip to the outside of the inner lip is 265mm (10.43").
  • From the mounting surface to the outside of the inner lip is 165mm (6.49").
  • Subtract 10" (the actual wheel width) from 10.43" and you get 0.43", which is the width of the inner lip.
  • Subtract the inner lip width, 0.43", from 6.49". As the wheel is 10" wide inside of the outer and inner lips, subtract half of that width from 6.09" to get the distance that the mounting surface is offset from the centerline of the wheel.
  • The offset would be 6.09" - 5.00", which is 1.09". That converts to 27.69mm offset.
Obviously, there is some margin of error here. However, it is quite apparent to me that the offsets of these front wheels are more akin to the ZL1 front offset of +23.
Astoc is offline   Reply With Quote
Old 07-16-2013, 09:40 AM   #2
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Where was this deal when I was looking around. Very nice looking. Should go fast.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 07-16-2013, 09:43 AM   #3
Astoc
Astoc's Avatar
Drives: 2011 Evo X
Originally Posted by daveagogo1 View Post
Should go fast.
I sure hope so.
Old 07-16-2013, 11:43 AM   #4
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
These will go very very fast. They were just finished about a week ago, so they're fresh off the line, 100% brand new. Good luck with the sale! Probably won't need any luck, they should go quick, certainly at that price
ModBargains.com is offline   Reply With Quote
Old 07-16-2013, 12:59 PM   #5
AUS10BMX
AUS10BMX's Avatar
Drives: 2010 2LT RY, 2014 Silverado
Holy...
With the offsets where exactly would they sit with the fenders? And would the tire sizes you mentioned, would that sit about where stock SS wheels are.
I use to have the 19" stock wheels on mine and they were the same height.
Clear Brembos?
No centering rings required?
Hypertech | Airaid | JBA Exhaust | RX Catch Can/CNC TB/Black Ice-Olator | Ported Intake/Heads | 1LE Brembos | F14's | RS Headlights | ZL1 Grille
AUS10BMX is offline   Reply With Quote
Old 07-16-2013, 01:17 PM   #6
Astoc
Astoc's Avatar
Drives: 2011 Evo X
Originally Posted by AUS10BMX View Post
Holy...
Clear Brembos?
The rear wheels should be flush with the fenders when running 305's. The fronts will have a small amount of poke when running 295's. 285's would see a more flush fitment in the front. They'll fit similarly to how the ZL1's stock wheels fit, I would imagine. They'll clear the Brembos, without a doubt.
From past experience with Forgestar wheels, the wheels will either include center rings, or the hub bores will be the appropriate size.
Old 07-16-2013, 07:22 PM   #7
L99CAMA2011
L99CAMA2011's Avatar
You first posted about these wheels over a month ago on another thread, wish I had saw it before I bought the TSWs. Man.
Old 07-19-2013, 08:37 AM   #8
Astoc
Astoc's Avatar
Drives: 2011 Evo X
Bump.
Old 07-19-2013, 10:08 AM   #9
stangkilr
stangkilr's Avatar
Drives: 2017 Camaro ZL1
Wish these were 18's
2017 ZL1
2014 Corvette
2002 Camaro
stangkilr is offline   Reply With Quote
Old 07-19-2013, 04:54 PM   #10
zogster
Drives: 2014 RRM ZL1 M6
Sending PM...
zogster is offline   Reply With Quote
Old 07-19-2013, 06:59 PM   #11
AUS10BMX
AUS10BMX's Avatar
I'm interested. Just trying to justify the offsets. I'd have to go with a 40/45-19, 30-19 would be to low as I need to stay at stock overall height, car isn't lowered and would look odd. If you could find out what the offsets are or have ModB chime in that would be great. Although they clear Brems, mine have the "roller skates" so wondering if those will make the fit.
Old 07-19-2013, 08:27 PM   #12
Astoc
Astoc's Avatar
Drives: 2011 Evo X
As far as I know, the offsets are +35 front, +39 rear.
Old 07-20-2013, 10:48 AM   #13
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
nice rims!
franknbeans is offline   Reply With Quote
Old 07-23-2013, 09:08 AM   #14
Astoc
Astoc's Avatar
Drives: 2011 Evo X
Bump!
