Solo Performance
Old 07-16-2013, 01:30 PM   #1
SSBN625Starr
Drives: Inferno Orange Metallic ZL1
ZL1 Brake Calipers
Does anyone know why the brake calipers on the rear brakes are located at the rear of the brakes instead of on the front of the brakes? I understood that it was best for handling if the calipers were located on the front side of the rear brakes.
Was it for overall weight distribution?
SSBN625Starr is offline   Reply With Quote
Old 07-16-2013, 01:45 PM   #2
Supersonick
Drives: Camaro ZL1 Inferno Orange
do you mean at the rear of the disk and not in front? the location is due to have the bigger brake power with the less fatigue to the caliper itself and its connections.
Supersonick is offline   Reply With Quote
Old 07-16-2013, 01:48 PM   #3
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
Whom exactly told you that handling was best with the calipers near the front? Do you have a source to link? I have never heard that and would think it did not matter due to it all being unsprung weight anyway!
ZL1-V is offline   Reply With Quote
Old 07-16-2013, 03:12 PM   #4
SSBN625Starr
I think I first heard it while watching Mecum Auctions.
Old 07-16-2013, 03:30 PM   #5
SSBN625Starr
If the ZL1 brakes are indeed unsprung brakes, that would explain it. Then you should mount them on the rear side of the discs to help out with overall front to back weight ratio.
If they are part of an inboard brake system, then they should be mounted on the front side of the discs. See the explanation here:
http://en.wikipedia.org/wiki/Inboard_brake
Old 08-06-2013, 03:27 AM   #6
NightmareZL1
Can't stop ***ifying
NightmareZL1's Avatar
Drives: Ashen 2013 Gray ZL1
The zl1 does not have an inboard/unsprung brake system. Our brakes move up and down with the wheels. They are sprung. Inboard systems mount adjacent to differential, before the half shafts to the wheels. I saw an old jaguar that had it.
NightmareZL1 is offline   Reply With Quote
Old 08-06-2013, 11:54 AM   #7
DavidW
Drives: 2013 ZL1 Vert Auto IOM
isn't sprung weight everthing that does not move with the wheels , like the body of the car , and unsprung weight is "below" the springs , like the wheels , brakes , control arms
DavidW is offline   Reply With Quote
Old 08-06-2013, 07:47 PM   #8
dimitri
Drives: 06 M5/04 350Z
i am confused
dimitri is offline   Reply With Quote
Old 08-06-2013, 10:59 PM   #9
OldScoolCamaro
...the only thing I can say is that I burnished the breaks properly during the recommended break in, and had the opportunity to make a high speed stop. Flawless setup. Most amazing .
Old 08-07-2013, 02:39 PM   #10
ZL1-V
ZL1-V's Avatar
Here you go Dimitri,
Let's try this again. I think the post from SSBN625Starr about inboard systems threw a few people?
http://en.wikipedia.org/wiki/Unsprung_mass
Also a video that explains what the term really means.
http://youtu.be/VW5YumiMIPA
Old 08-07-2013, 06:16 PM   #11
dimitri
Thanks
Old 08-07-2013, 06:18 PM   #12
dimitri
Originally Posted by dimitri View Post
Thanks
Youtube video gsve good explanation
