JUICEDMOTORSPORTS
Old 07-16-2013, 06:19 PM   #1
SPCBA
Drives: pleather and Chiclets
RacingBrake caliper rebuild DIY
Done with simple hand tools that anyone has
step 1 remove caliper from
spindle and the lines from caliper
prepare to catch brake fluid and dont lose the crush washers
disassemble the pads from the caliper using a hammer and punch of small screw driver. once pins are removed clip comes out and pads slide out
caliper removed and clear of pads looks like this. prepare to take dust boots out
i used a small SOFT metal screw driver to fit between dust boots and caliper. soft metal screw driver so you don't score or gouge the caliper
to take pistons out I used the same screwdriver and some channel locks. be gentle and take your time. when using channel locks it might take some twisting
the oil seal is the same...small soft screw driver and patience
I did mine on card board so the extra fluid in caliper didnt stain my work area and made for easy clean up
this is the bag of goodies supplied by racing brake. includes lube, pistons, dust boots, and oil ring seals. all packaged very nicely.
the pistons are different sizes and have matching seals and boots for each size
push in new oil seals with finger, once in the groove they fit nicely...again use the right size!
slip dust boots onto the new pistons...remember big on big small on small!
generously lube the new pistons with supplied lube to make reassembly much much easier
gently slide new pistons in the correct hole in the caliper
make sure new dust boot seats properly
before inserting piston all the way in
i was a little afraid of damaging my caliper by applying uneven pressure when inserting new pistons so i used a small hand clamp
gentle pressure and they literally pop in. using liberal amounts of lube makes it easier and using your fingers to insert piston is fine as long as you use consistent pressure on all sides of piston.
reassemble caliper to spindle and put pads back in. dont forget to bleed the brakes and or do a complete flush with dot 4 fluid while you are at it
SPCBA is offline   Reply With Quote
Old 07-16-2013, 06:20 PM   #2
SPCBA
video of dust boots being popped out
easiest way to get pistons out is to blow compressed air through this slot...excuse my wrong language, english is hard
taking pistons out using tools everyone has
Old 07-16-2013, 09:06 PM   #3
nitto85
Caffeine Injected
Drives: Chevrolets!!
Awesome post.
What made you decide to rebuild?
nitto85 is offline   Reply With Quote
Old 07-16-2013, 09:43 PM   #4
SPCBA
added heat management of the pistons and i fried my boots and seals. wanted to rebuild before i sell to a v6 guy as i am upgrading the calipers. pedal felt better as well
Old 07-16-2013, 09:46 PM   #5
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
Awesome Blake!
Project MantaRay...Underway
GunnyG is offline   Reply With Quote
Old 07-16-2013, 10:39 PM   #6
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Good DIY.
Here is another post/video...
http://www.camaro5.com/forums/showthread.php?t=305558
Besides, yours do not look bad.... these look bad....
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 07-16-2013, 11:40 PM   #7
SPCBA
those were my rears that had been rebuilt with oem products already. my fronts the dust boots were next to impossible to remove and i spent a few hours taking them out piece by piece.
my new calipers will be manufactured properly and will not need or require dust boots
Old 07-17-2013, 08:08 AM   #8
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Good write-up
jeremywes is offline   Reply With Quote
Old 07-17-2013, 01:13 PM   #9
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Nice write up!
Best regards,
Tyler
888-308-6007
Old 07-17-2013, 01:21 PM   #10
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Nice job. What did you use to plug the brake line so that it didn't leak the master dry?
1977and2010 is offline   Reply With Quote
Old 07-17-2013, 01:26 PM   #11
Synner
Drives: not stock
You can use a metric bolt (I think they're M10?, whatever the banjo bolt is), nut, and 2 rubber washers. Worked great when I did my swap.
Old 07-17-2013, 04:45 PM   #12
1977and2010
Thank you sir.
Old 07-17-2013, 07:11 PM   #13
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
I like to put a piece of wood between caliper and use an air pump wherethe brake hose goes. All 4 pistons pop out evenly.
Also, i take off bleeders and blow fluid on one side and have it come out the other to clean internals.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 07-18-2013, 11:28 AM   #14
SPCBA
i did something similar to that the other ines rebuilding...i was trying to do a write up for the every day guy with simple hand tools.
to he question about saving fluid...i let mine leak dry and changed fluid... i like to change fluid often because of the abuse mine takes being an auto on road course.
