Old 07-17-2013, 10:00 AM   #1
camaro-heater
22 years of slammin gears
camaro-heater's Avatar
Drives: 2010 Camaro SS M6
Setting toe on rear end..
I'm probably an idiot but going to ask this anyway... I ordered the Pfadt rear trailing arm and rear tie rod package. In the directions it says after installing the rear tie rods you will need to set the toe.. If these are solid and non-adjustable, how will i be able to do that? Or will I not. This is probably a no-brainer but somebody be nice and help me out thank you
2010 1SS/RS-M6 > SIM w/matte black stripes.
Engine/Performance> Magnuson TVS2300 @ 8lbs-Hennessey CAI-SLP 1 3/4" longtube headers w/ HF cats X pipe SLP Powerflow muffler-QTP dual oval electric cutouts-ZL1 fuel pump-RX catch can-ADM race air scoop,WW relocate-Hurst short throw shifter-
Tuned by: Boost Performance 550rwhp/538tq.
Drivetrain> DSS 3.5" aluminum ds-Street Slayer Twin Carbon-IdealG master cylinder-Tick ss clutch line&speed bleeder-GFORCE 1500 Outlaw axles-JRE rear end pkg(LPE 3.70's,true trac,billet main caps)-LPW rear cover-Nitto NT05's. Suspension> Minor stuff/bushings
camaro-heater is offline   Reply With Quote
Old 07-17-2013, 10:22 AM   #2
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
Toe rods?
You need an alignment after replacing the toe rods. Pfadt can provide you with performance alignment specs.
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
Old 07-17-2013, 11:00 AM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
They are adjusted using the OEM "eccentric" bolts, which are shaped kinda oblong to allow adjustment. If I remember correctly, the inner bolt on the toe rods is an eccentric bolt. If you're installing non-adjustable arms, the best thing to do is to mark the head of the bolt and the adjacent frame so that the same adjustment can be maintained with the new arms. After that.....it is still advisable to go get an alignment.
blazzin1 is online now   Reply With Quote
Old 07-17-2013, 11:38 AM   #4
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Tru dat!
jeremywes is offline   Reply With Quote
Old 07-17-2013, 07:02 PM   #5
camaro-heater
Thank you very much!
Old 07-17-2013, 11:57 PM   #6
grocerygetter
instigator
grocerygetter's Avatar
My toe was so far out after installing those I had rubber piled up by the license plate after driving 35 miles on the interstate to get my alignment done. Lol....FOR SURE get an alignment.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 07-18-2013, 12:52 AM   #7
camaro-heater
Thats good to know lol, will for sure do that then!
