Old 07-17-2013, 12:41 PM   #1
Scott 78
Scott 78's Avatar
Drives: 2014 SIM SS 6M
17" Rims
Will 17s fit over the V6 calipers?
These are what I'm looking at -
http://www.alliedwheel.com/wheel.php?name=Black+Daytona
Scott 78 is offline   Reply With Quote
Old 07-17-2013, 02:52 PM   #2
parkermoeder
parkermoeder's Avatar
Drives: 2011 Camaro ss
do you want to but my 20in stock ss rims? they are currently plasti dipped. i will give you a good price just to keep those other rims off a camaro
http://www.camaro5.com/forums/showthread.php?t=306219
[2011 Camaro 2ss L99
-OEM Painted GFX
-Borla Atak axle back
-Stainless Power headers
-Cold Air Inductions Intake
-Blue oracle halos
-Satin black ZL1 replicas
-315 invos and other cosmetic mods
parkermoeder is offline   Reply With Quote
Old 07-17-2013, 04:08 PM   #3
Scott 78
Scott 78's Avatar
Those 20's are the ugliest rim in the world. I'm doing a racing build.
Old 07-17-2013, 04:15 PM   #4
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Those 17's you're looking at won't work.....not because of the diameter, but because the bolt pattern is incorrect. You must have 5x120mm bolt pattern. Actually, the 5x4.75" will fit....but it's not exact. I know that Bogart makes a 16" rear drag wheel that will fit over the V6 brake system, at least on the rear, not sure about the fronts. So I would assume there are other 17" wheels that would fit, but it's going to need to be the correct bolt pattern and offset/backspace.
blazzin1 is offline   Reply With Quote
Old 07-17-2013, 04:42 PM   #5
Scott 78
Scott 78's Avatar
I understand the offset and bolt pattern are off on that wheel. I'm more concerned about 17s fitting around the brakes. Thanks for the heads up Blazzin. I love how your car looks btw.
Old 07-17-2013, 05:04 PM   #6
blazzin1
blazzin1's Avatar
Yes, I would say that a 17" diameter wheel should fit fine over the V6 Brakes......(as I said before, as long as the bolt pattern and offsets are correct). Thanks for the compliment on my car. In "my garage", there are pictures of my car with my previous set of 17" Weld Wheels (installed over the Brembo Brakes). Hoping to sell my current wheels this Winter and go back to the Welds....I miss them!!!
Old 07-17-2013, 09:29 PM   #7
parkermoeder
What racing build are you doing with your v6?
-OEM Painted GFX
-Blue oracle halos
Old 07-17-2013, 10:58 PM   #8
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
17s fit on the V6 with no issue (generally). 16s can be run on the V6 brakes. Here's my car on 17s:
Pic isn't great, but it gives you an idea. I'm dropped roughly 2" all the way around as well.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 07-18-2013, 09:46 AM   #9
Scott 78
Scott 78's Avatar
Thanks for the info 2SS45th. That's a great looking car. I love the stance.
Parkermoeder, I'm building the car as an oval track car. No sanctioning body in particular but I want it to mirror my real race car.
I can't tell if you were trying to be condescending or not with you "V6" comment. When I finish this build I'd like to offer you the opportunity to come up here and put your SS up against my V6. Doesn't matter how much HP you put out if you can't get it to turn at the end of the shoot.
Old 07-18-2013, 09:57 AM   #10
parkermoeder
wasnt make a v6 hate comment was wondering if you were make a turbo v6 comment and yea thatd be fun just tell me when you are done
-OEM Painted GFX
-Blue oracle halos
Old 07-18-2013, 10:59 AM   #11
Scott 78
Scott 78's Avatar
No turbo or power adders yet. I will being doing a CAI eventually. I'm going to focus on handling first. Pfadt stage 4 kit is in the works.
Sorry if I came off a little jaggy. Lots of guys here look down on the 6bangers.
Old 07-18-2013, 11:52 AM   #12
2SS45th
2SS45th's Avatar
Thanks! I too had a strong focus on suspension, just instead of cornering it's setup for straight line
Old 07-18-2013, 03:36 PM   #13
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
If its a racing build, wouldnt bigger brakes be paramount? Why limit urself to the little v6 brakes?
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 07-18-2013, 04:09 PM   #14
Scott 78
Scott 78's Avatar
Bigger doesn't always mean better. On the race car we ran 11.25" rotors. Albeit with 4 piston calipers. I'm still working out the brake situation. But it's in the works.
