Old 07-17-2013, 01:51 PM   #1
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Maggie = Weeping rear seal.
Too much crankcase pressure. Getting oil spots on my floor after I walk on it during a cruise.
I took the pvc hose off at the blower snout and tried to suck on it. Could barely pull anything. No way that could keep up to crank case pressure under boost.
I took the barb out of the rear drivers valve cover (LS3) and drilled it out to 5/16".
I also removed the check valve from my RX catch can. I just sawed the bottom 1/8" off the fitting where the lip is that holds the check ball in. The valve falls out and then you have to pull the spring out with needle nose pliers.
Now I'm getting some flow through there and no more oil spots on my floor. And it runs perfectly as there is no extra unmetered air (like running a breather) going through. I highly recommend this mod.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 07-17-2013, 03:19 PM   #2
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
that's odd I had to add a check valve to my Norris can to keep from sucking oil out of the catch can
bmbbl be is offline   Reply With Quote
Old 07-17-2013, 05:56 PM   #3
willhe64
willhe64's Avatar
Are you sure? How could that work? A one way valve is just that.
Old 07-17-2013, 11:41 PM   #4
grocerygetter
instigator
grocerygetter's Avatar
Dual catch cans ftw...or none at all if your car runs clean.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 07-18-2013, 09:53 AM   #5
bmbbl be
bmbbl be's Avatar
from the way I understand it opens and closes.... it cured the problem, because I was getting a lot of oil through the intake and smoke out the exhaust
if I were you I would call tracy at rev extreme ,,he is good guy that can help you
Old 08-14-2013, 11:39 AM   #6
willhe64
willhe64's Avatar
LOL!
Old 08-14-2013, 12:17 PM   #7
Unreal
Drives: 2006 Z06
I'm a huge fan of dual vented catch cans. The AGP kit comes standard with them and I'm converting over. I have a RX monster can but it just can't move enough air.
Nick
Corvette Z06 -1200ish rwhp
Old 08-14-2013, 12:42 PM   #8
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
If the Maggie snout port is never pressurized, there should not be the need for a check valve in the exhaust port of the catch can in the first place.
2SSCAMARO is offline   Reply With Quote
Old 08-14-2013, 12:55 PM   #9
willhe64
willhe64's Avatar
This. There have been people reporting issues with the valve sticking too. It's a cheapo plastic ball.
Old 08-18-2013, 09:49 AM   #10
willhe64
willhe64's Avatar
I was detailing my engine bay yesterday and discovered that the maggie is now weeping oil. Looks like the rear gear case. This sucks. Looks like I'll have to pull it off and send it away.
Old 08-18-2013, 04:29 PM   #11
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Sucks to have to pull it. I went with no catch can and had no problems (10psi). I had close to 40k on the motor before the S/C and intake was clean. I'm not really getting the whole catch can thing.
Nitroman28 is offline   Reply With Quote
Old 08-21-2013, 07:45 PM   #12
Magnuson Superchargers
Magnuson Superchargers's Avatar
Drives: Supercharged
Did you already call and get an RGA #? Please let e know if there is anything i can help with.
Magnuson Superchargers is offline   Reply With Quote
