BORLA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 07-17-2013, 05:43 PM   #1
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
19 inch rims, looking for track tires that work.
Hi guys, I have searched the forums a little but have not found a clear answer. I have attempted to run toyo R888 rubber and TSW 19" rims that fit directly on a CTS-V coupe on my ZL1 at the racetrack. The tires are just about exactly 2" shorter than stock front and rear according to the spec sheets. I had to change wheel studs and run spacers on the front to give me more offset. Current Toyo tires are 295/30/19 front and 305/30/19 rear and fit without a problem. These tires and wheels cannot seem to run in any traction control mode without a stability control error and reduced power mode. I would prefer to at least have the option of using some traction control if I let someone else drive the car. To make the traction control work do I need to scrap the 19" rims or will a taller Hoosier R6 in 295/35/19 and 315/35/19 work? Has anyone tried any of these combinations on a ZL1 for the road course? Is there another size of track tire that works with the traction control that I could swap directly?
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 07-20-2013, 07:06 AM   #2
L99CAMA2011
L99CAMA2011's Avatar
I didn't feel safe with the Hoosier load rating for our heavier cars. I would go with the 35 instead of the 30 IMHO. What are the rim widths.
Old 07-20-2013, 02:07 PM   #3
jessrayo
Speed Freak
jessrayo's Avatar
I noticed the load rating is less on the Hoosiers than the Toyo's but it still covers the axel weight of the car. Others have told me it should be fine... I don't know for sure. I don't remember the exact size of the rims on the car but I for some reason I think they are 9.5" front and 10" rear if that would even be a reasonable fit on this car.
Old 08-02-2013, 06:17 PM   #4
jessrayo
Speed Freak
jessrayo's Avatar
Okay, I spent the entire day at the race track today. Outdoor temperatures started in the 90's and ended up around 106. I had no trouble at all with the traction control and the toyo R888's on 19" rims did pretty well. There were not many cars out today but the Camaro did very well all things considered. I had to run a gear high to keep my rpm's down and that helped control heat issues, at least until I would get a Porsche in my sites and then I would pick it up to run him down and start to over-heat.... I will go to Hoosier R6's eventually but I really need more time in the car before I make some more performance changes. I need more cooling for the supercharger, may roll back the boost a little, may put in a remote reservoir, may go with a Freon based chiller.....
Old 08-02-2013, 06:20 PM   #5
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
Not a ZL1, but run 19" R888 all around. 305/19 in the front and a 315/19 in the back, never any issues when taking it out on a road course.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 08-02-2013, 07:19 PM   #6
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
I would love to see results of the chiller in this setting.
...even for drag racing
Trackman is offline   Reply With Quote
Old 08-03-2013, 07:46 AM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
I just purchased R888s in size 285/35/20 all the way around. Offset 30mm. I haven't tried them yet to see if the computer goes crazy at the road course. They fit great and the height is very similar to stock.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 08-03-2013, 03:06 PM   #8
jessrayo
Speed Freak
jessrayo's Avatar
You should be fine with the computer. The problems that I had the last time were actually from the throttle body because the traction control would try to roll back the throttle when the car was sliding or spinning and either because of improper spring tension or boost vacuum or something the throttle would not respond... It would then put the car in limp mode and show "stabilitrack error" on the dash, I guess thinking it better shut the car off or I would spin out and crash. Once the throttle body was fixed it ran great in any mode and though I did not get it on video, I almost did a complete donut in turn 11 drifting a little too wide... I put my track video on my build thread and I'm linking it here if you want to see the car on the track.
http://www.camaro5.com/forums/showth...=304554&page=2
