sjm autoprod
Old 07-17-2013, 06:22 PM   #1
jake2212
jake2212's Avatar
Drives: 2010 camaro 1ss/rs A6 Supercharged
3.91s in an a6 ss
I was wondering how well the 3.91s from the 1le would perform if I put them in my ss. Thanks for the input
Check out my build thread: Project Ultimate Street Camaro
http://www.camaro5.com/forums/showthread.php?t=378443
jake2212 is offline   Reply With Quote
Old 07-17-2013, 06:28 PM   #2
dixonk
dixonk's Avatar
Drives: 2011 Audi Q7
Send a message via Skype™ to dixonk
Traction will be an issue.
dixonk is offline   Reply With Quote
Old 07-17-2013, 07:11 PM   #3
jake2212
jake2212's Avatar
How so?
Old 07-17-2013, 08:16 PM   #4
dixonk
dixonk's Avatar
1st gear will be very steep. 2nd gear will start getting good.
Old 07-17-2013, 08:17 PM   #5
dixonk
dixonk's Avatar
Also if you start adding power to the car it will get worse.
Old 07-17-2013, 08:20 PM   #6
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
I would imagine a good set of tires and a good tune would put you in the green. I don't think it would be much different than say 18" tires but that's just a guess.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 07-17-2013, 09:49 PM   #7
jake2212
jake2212's Avatar
Well I'm swapping out my wheels and tires for zl1 wheels and tires
Old 07-17-2013, 10:01 PM   #8
jake2212
jake2212's Avatar
Well I am getting better tires so that should def help. But there should be no problems other than traction?
Old 07-17-2013, 11:54 PM   #9
niznos
niznos's Avatar
Drives: 2010 2SS MT RS
You should read the sticky "rear end gears 101." I think your 1st gear would be wasted. The auto SS should go with 3.73. I wouldn't experiment with anything higher given the expense of this modification, because it will be just as expensive to undo it.
niznos is offline   Reply With Quote
Old 07-18-2013, 12:34 AM   #10
dixonk
dixonk's Avatar
Have you tried hooking up with stock rear diff and stock tires yet? You'll find the 3.27 doesn't have a problem spinning a tire.
Old 07-18-2013, 09:47 AM   #11
gr8daneh
460 RWHP 420 RWTQ
gr8daneh's Avatar
Drives: 2SS/RS - IBM LS3 M6
I changed out my diff to 3.91's and holy sh!t did it make a huge difference. The driving band is so much better in all gears and it pulls like a raped ape! Best mod I ever did so far....my gas mileage has not suffered a bit...
gr8daneh is offline   Reply With Quote
Old 07-18-2013, 12:21 PM   #12
OmniCamaro
US Veteran
OmniCamaro's Avatar
Good to know! How about your tune? Do you have a thread on your experience specifically? I'd like to see the whole process to learn how/what to do/not to do. Thanks!
Old 07-18-2013, 12:35 PM   #13
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
They'll be hard to hook WOT in 1st and maybe 2nd on street tires, but I woudn't mind more gear when I'm cruising at 50-60mph. Going WOT then is not always impressive.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-18-2013, 12:40 PM   #14
steveo9043
steveo9043's Avatar
Drives: 2012 45th AE 2SS Coupe
he has a LS3 M6 according to his info on the left. Thats different then an A6
2012 45th L99 SS-Cold air inductions CAI-Dynatech LT's-Solo mach XL catback
333hp/341tq (before LT's)
steveo9043 is offline   Reply With Quote
