BORLA
Old 07-18-2013, 12:13 AM   #1
Subzero
Subzero's Avatar
Drives: Black 2012 2SS/RS Convertible
Barton Shifter Noise
Hey all!
I recently finished installing a barton short shifter for my '12 2SS/RS Convertible. Rowing the gears is buttery smooth and the shifter is quite firm, however there is quite a bit of noise translated from the transmission - enough to hear with the top down. Under hard acceleration it rattles like crazy when I'm not holding it, but after I hold it, it sounds like two smooth stones rubbing together very loudly. The rattling only happens during acceleration - the stone sound happens during 2k+ RPMs while parked. I notice the stone sound gets much more pronounced when it's in gear and the shifter is held to the left or right (very lightly).
So far I've tried screwing the flat shaft + ball down as far as they can go and re-tightening everything up. But it still rattles and the stone grinding sound is still there.
Has anyone encountered this? I really don't want to get another shifter - I returned the hurst due to similar issues.
Subzero is offline   Reply With Quote
Old 07-18-2013, 01:10 AM   #2
Lombardi
Lombardi's Avatar
Drives: 2010 ABM Camaro 1LT
I dont have a barton but I have the Hurst in my car. Their performance shifters and will natirally translate more noise then a stock shifter. So much that the hirst shifter comes with some dyno mat like material you can apply to quiet it but it hinders some of the performance aspects. I cant hear the noise in your car personally but I can say mine can me noisy too. Its the nature of the beast.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Lombardi is offline   Reply With Quote
Old 07-19-2013, 07:55 AM   #3
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
Just had this problem when I helped a buddy install a barton shifter. Get some dynamat or equivalent and put some on the bottom of the shifter under the car where the shifter connects to the fork of the transmission, under the black rub boot. Here is a picture of where to put the dynamat from left to right covering both ends. I put a red line to show where you need to cover with the dynamat.
c_LoW29 is offline   Reply With Quote
Old 07-19-2013, 07:59 AM   #4
c_LoW29
If you want to make it dead silent add some teflon tap to the threads of the shifter then put which ever stick you are using back on. Here is a picture of the threads i am speaking of
Old 07-20-2013, 05:51 PM   #5
Gforce8
WFO all the way
Gforce8's Avatar
Drives: Hyper Blue 2SS, Kalahari, 6 speed
I have the same problem and I'm actually thinking about selling it and putting the OEM one back in. I love the feel but hate the noise.
I tried teflon tape and various other things on the upper thread, never on the lower. Do you really think his will help?
If you try it subzero, let me know!!
Thanks
2016 2SS -no mods
Gforce8 is offline   Reply With Quote
Old 07-21-2013, 05:35 AM   #6
Subzero
Subzero's Avatar
When I tightened everything up the first time, I wrapped both the shifter knob screw as well as the shift lever screw with teflon tape. It was just as if I didn't do anything at all to it. The noise is still there, but after a week of driving it seems to have subsided a tad. I still get the rattle under acceleration but the grinding sound seems to have been reduced; though I'm not sure if that's because of the cool-down we've had recently (it was 95 -100F for a couple days). Apparently a weighted aluminum shift knob is the way to go to get rid of the rattle. Weigh your stock shift knob - it's pretty heavy. I'll give it another week or two before I go with MGW.
BTW, how has the dynamat mod worked for noise reduction? Is most of it gone?
Old 07-21-2013, 08:17 AM   #7
c_LoW29
Thanks
Put a piece of dynamat on the bottom of the shifter in picture one I promise you it will help. Make sure it's long enough to cover both ends of the locking pin that goes through the shifter
Old 08-04-2013, 02:06 AM   #8
Subzero
Subzero's Avatar
After all of that, I ended up swapping the barton out for the MGW. A complete night and day difference. The MGW is quite a bit heavier, thus no rattling at all. The 10% throw increase made shifting easier - you don't force gears anymore. It also has built in side to side spring tension so it returns to neutral much quicker. All in all, I'm much much happier.
Old 08-09-2013, 09:41 PM   #9
Gforce8
WFO all the way
Gforce8's Avatar
Great to hear. I will try the MGW or MTI racing they seem to have the rubber vibration isolator bushing inside the shifter rod itself like OEM part.
A piece of dynamat is not a fix I think.
Thanks!!
2016 2SS -no mods
