GM Parts House
Old 07-18-2013, 11:53 AM   #1
CTcamaro1
Drives: 2012 camaro ls/rs
catch can install
i will be getting my catch can today in the mail so i think i am going to install it today with a friend. how hard of an install is it? and any tips or tricks? its the rx catch can
CTcamaro1 is offline   Reply With Quote
Old 07-18-2013, 11:59 AM   #2
NYJets77
Drives: 2013 2LT/RS Summit White
Very easy
15 mins
double check that you don't switch the hoses
NYJets77 is offline   Reply With Quote
Old 07-18-2013, 12:10 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Yep it's a very easy install. If you do a search on here, you can find a few threads with pics and tips. We are always happy to help if you run into a snag as well.
Best regards,
Tyler
888-308-6007
Old 07-18-2013, 09:25 PM   #4
CTcamaro1
did you guys use the stock hoses? or purchase more, i didnt connect it tonight because it looked like i needed more hose
Old 07-18-2013, 09:37 PM   #5
spyderbuddy
spyderbuddy's Avatar
I used more hose, just be carefull on they way it connects, I heard people blowing out there rear seals.
Pics if you need them
Gen5 DIY Frameless Mirror, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, Vararam Cold Air Intake, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
Old 07-18-2013, 09:41 PM   #6
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Very simple install. Simply but a line and slip the hose on. But another thing to be certain is that the drain valve is closed. You can check this by placing your finger on the drain and if you feel any suction then its open if not then your good.
Proud owner of litho #179 Click Picture for Build Thread
Old 07-18-2013, 09:50 PM   #7
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
JUST what I needed to read SOME PEOPLE have BLOWN out there rear SEALS!!!!!!! Now I know I'm not trying this Myself ???? YIKES <<<<
skipinminn is offline   Reply With Quote
Old 07-18-2013, 09:54 PM   #8
menendez1293
The only time this has happened is when people hook up the lines backwards and even then there are very few people this has happened to. I wouldn't worry to much about it. Both the Elite and Rx come with instructions while they are not the best they will guide you through it. And you can post up a picture on the forum when your done for us to verify for an extra safety measure
Old 07-18-2013, 09:56 PM   #9
skipinminn
Chiquita
Nope I will find a seller and Installer at C5fest and have it done
Old 07-18-2013, 11:02 PM   #10
CTcamaro1
where did you guys pick up the extra hose from? would i have to go to my dealer or can i just pick it up at an autozone or a home improvement store
Old 07-18-2013, 11:05 PM   #11
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: Longest things on Earth
Skip this one is a no brainer, you can pull this install off in half hour tops!
its a syn is offline   Reply With Quote
Old 07-18-2013, 11:06 PM   #12
its a syn
B.O.D. 02/16/10
its a syn's Avatar
O'Reilly's or any auto parts store. I had to go with blue hose the first go round because they didn't have black that day!!
Old 07-19-2013, 10:44 AM   #13
CTcamaro1
thanks guys ill install it today, ill let you know how it goes!!
Old 07-19-2013, 11:11 AM   #14
thxultra
thxultra's Avatar
Drives: Mean ass V6
Ok dummy question here, What does a catch can do?
thxultra is offline   Reply With Quote
