Old 07-19-2013, 12:24 PM   #15
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Originally Posted by thxultra View Post
Ok dummy question here, What does a catch can do?
A quick explanation is that it catches oil that could be ingested into your intake track. In the long run that oil that gets stuck in the intake can cause a decrease in both performance and efficiency. Simply Search the forum and you will find stacks of threads with a much longer and detailed explanation.
Proud owner of litho #179 Click Picture for Build Thread
Old 07-19-2013, 12:34 PM   #16
thxultra
thxultra's Avatar
Drives: Mean ass V6
Thanks for the explanation Been reading a lot on here about them so wanted to know the story.
thxultra is offline   Reply With Quote
Old 07-19-2013, 06:02 PM   #17
Roffo41
'13 V6 Camaro LT Owner
Drives: Camaro LT V6
Originally Posted by CTcamaro1 View Post
thanks guys ill install it today, ill let you know how it goes!!
How'd everything go?
Roffo41 is offline   Reply With Quote
Old 07-19-2013, 06:28 PM   #18
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
<<<<<NO BRAINER thats me <<<< LOL >>>>
skipinminn is offline   Reply With Quote
Old 07-19-2013, 08:11 PM   #19
rush2112
Drives: 2013 2LT Auto CRM. 2009 night train
What is the spec or pn of the hose needed?
rush2112 is offline   Reply With Quote
Old 07-19-2013, 08:37 PM   #20
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
As seen in the photos above, the hose to buy is Power Steering return hose.
http://www.autozone.com/autozone/par...mString=search
This is about an easy install job as you get. There are plenty of threads in this V6 section if you do a search on Catch Can. Again the photos above are a huge help.
Lastly, the reason to install one of these on our DI engines is we do not have fuel going thru our intake manifold to mix with that oil and prevent the sludge from building up on our valves.
This photo shows how much my catch can caught at my last oil change of 3500 miles. Now imagine all that oil going thru your intake on onto the valves.
Old 07-19-2013, 08:46 PM   #21
CTcamaro1
Drives: 2012 camaro ls/rs
didnt get to do it tonight guys, its about 100ish everyday here in connecticut to hot to do anything whether it takes 5 minutes or 5 hours!, however i did order my ported throttle body today ))))
CTcamaro1 is offline   Reply With Quote
Old 07-19-2013, 09:12 PM   #22
Kessler
Kessler's Avatar
Drives: 2012 IOM 2LT RS A6 w/ BA
Any one else notice any oil getting into the intake on the 'clean' side?
ToDones -
Apex Scoop & Washer Relocate - CAI cai - VMAX Ported Throttle-body -
Elite CC - Elite Clean Side Separator - MRT v1 Axle Back customized w/ J-Pipes -
Blacked Out Headlight/Tail Light Areas - Blacked Out BowTies - Blacked Out 'camaro'
Brake Light Chrome Bezel delete - Front Plate Relocate
JL Audio XD400/4 - Sub Thump Sub Box 2 10"s - DRL to Halos - Escort Redline
Gary's Customs ZL1 Front Bumper, ZL1 Rockers, & ZL1 Spoiler - Paint matched IOM
ToDos -
?Vitesse Throttle Response Controller?
Kessler is offline   Reply With Quote
Old 07-20-2013, 09:28 AM   #23
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
Prior to my CC install, I had a bit of oil coming thru the clean side into the intake tube (ahead of the throttle body). My TB was pretty dirty, too. Since my CC and breather install, I have taken the intake tube off once to check, and again when I installed my Roto-Fab intake, and both times it's been clean.
You can see the oil that came from the clean side into the intake tube in the first pic in this thread.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 07-20-2013, 10:01 AM   #24
CTcamaro1
are the hoses a universal fit? or is it a specific size?
Old 07-20-2013, 12:27 PM   #25
rtcat600man
Another choice is Transmission Oil Cooler lines.
The size you want is 3/8 I.D.
Old 07-20-2013, 01:40 PM   #26
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
Rear of valve cover to center port on the RX catch can... Outside port of the catch can to center of intake breather hole, (you will have to cut the plastic hardline to the nipple that fits the intake, the 3/8 hose will slide right over it and seal fine).
I bought appx 4 ft of 3/8" Trans cooler hose from O'Reilly's auto parts, it was about $13 bucks for the hose.
Picture below of oil in bottle is what I drained today (just checking to see if it was actually catching anything)... It looks like appx. 1 to 1.5 Tablespoons of oil... This much after only 200 miles of having the catch can on the car... This is more than I was getting out of my LS3 car in 4000-5000 miles... Sad face.
Jason@ is offline   Reply With Quote
Old 07-20-2013, 03:56 PM   #27
CTcamaro1
would i be able to get it at the store or would they have to order it specifically for my car
Old 07-20-2013, 04:43 PM   #28
batman53201
Account not blocked
batman53201's Avatar
Drives: The Batmobile
i installed the elite on mine skip. its the easiest mod i have done.
batman53201 is offline   Reply With Quote
