Anthony @ LG Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 07-18-2013, 03:45 PM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '15 Z/28
new road course setup 20"
just got my road course "square" setup from tire rack and they fit great...wheels are cheap $203 each and tires are toyo proxes r888 285/35-20 $378 each. wheel link http://www.tirerack.com/wheels/Wheel...wheelModel=Z32 30mm offset and they look fine and clear everything.
I had them heat cycled at $15 each and tire pressure sensors installed.
'15 Z/28 #325 black a/c & stereo. 2:10.9 VIR Full 1:44.74 Summit Point Shenandoah Circuit
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 07-18-2013, 03:46 PM   #2
Stephen12ZL1
Drives: '15 Z/28
close up
Old 07-18-2013, 05:28 PM   #3
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Nice looking set-up. If you don't mind me asking, why are you not running a wider tire in the back? Just for the ability to rotate fronts and rears?
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, ADM trunk intercooler reservoir & EMP pump, Ron Davis S/C heat ex, and radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1200+... 203.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 07-18-2013, 05:32 PM   #4
Diode Dynamics
Diode Dynamics's Avatar
Drives: Camaro Lighting Experts
square setups are typically better on a road course and don't generate as many negative handling characteristics.
But staggered setups help with a launch at the drag strip...and look really good IMO lol
-Nick C.
Diode Dynamics is offline   Reply With Quote
Old 07-18-2013, 05:45 PM   #5
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
had no issues at all spanking vettes on MSR long course with 315s and 275s and kicks butt at autocross as well.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 07-18-2013, 07:04 PM   #6
Stephen12ZL1
Drives: '15 Z/28
Just as stated....I can rotate tires if necessary with my square setup
Old 07-18-2013, 08:52 PM   #7
Smittty
Smittty's Avatar
Drives: 2013 ZL1 Camaro 2000 SLP Camaro
I like the the setup.
Smittty is offline   Reply With Quote
Old 07-18-2013, 09:26 PM   #8
roSSco
∞ Smiles per mile
roSSco's Avatar
Drives: 2013 ZL1 Summit White A6
Looks good.
I'd like to go with a 295 setup on all four corners. Those would require a 10.5" or 11" wheel wouldn't they?
2013 ZL1 #4739
'Heisenberg'
Color - Walter White
Roto-Fab CAI
On Reddit? Check out /r/ZL1/
roSSco is offline   Reply With Quote
Old 07-19-2013, 07:19 AM   #9
Stephen12ZL1
Drives: '15 Z/28
I think 10" like these would be fine but some companies don't want to put 295s on the front due to possible clearance issues.
Old 07-19-2013, 09:12 AM   #10
roSSco
∞ Smiles per mile
roSSco's Avatar
I like how tirerack puts the weight of the wheel on their page. I noticed the wheels in OP are about 5 pounds heavier than some of the others. 5 pounds per corner is a big deal.
Does anyone know what stock ZL1 wheels weigh?
Edit: it looks like the fronts are ~27lbs and the rears are ~28lbs.
http://www.camaro5.com/forums/showthread.php?t=219198
Old 07-19-2013, 10:43 PM   #11
tsnow
tsnow's Avatar
Drives: 12' ZL1, AGM 6M
Did you contemplate 19"s, a la Z28?
The black complements your car well. Very nice, an updated old school look.
tsnow is offline   Reply With Quote
Old 07-19-2013, 11:06 PM   #12
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2012 CTS-V coupe
I like these. Come in 20x10, 23 and 35 offsets for front and rear. Right at $790 a set delivered. No idea on the weight though.
http://www.discounttiredirect.com/di...=10&vid=023651
REDLINE
2016 Corvette Z06 3LZ
Callaway SC757
"I lived my life by one motto.......mottos are for losers" cvp33
cvp33 is offline   Reply With Quote
Old 07-19-2013, 11:11 PM   #13
Stephen12ZL1
Drives: '15 Z/28
I saw those too...for drag radials I think they would be great too. I got the above wheels because of the 30mm offset so I can use the same wheel front and rear.
Old 07-19-2013, 11:26 PM   #14
cvp33
America FVCK Yeah!
cvp33's Avatar
Being from VA you must run VIR? I love that place! Only 45 mins from my house. Need to trade my 'vert for a coupe at the end of the summer and get to racing again. God I miss it!
REDLINE
Callaway SC757
