Gen5DIY
Old 07-19-2013, 11:10 PM   #1
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Back to Back Comparison: NGKs vs ZR1 Plugs
Hey guys, this has been a hotly debated topic around here it seems, so I took the time today to go ahead try out both sets now. So, the plugs were swapped today, and in 300 miles I'll pull a plug in the ZR1s for comparison in regards to cleanliness. Anyways, here's the NGK after 300 miles:
So, not too impressed. Quite a bit of loose soot around the plug.
Now, on to the driving impressions. All I can say is WOW! I didn't think that $80 of spark plugs would make that big of a difference. The car idles better, comes off of idle better, runs at lower rpms better, and pulls harder too! You can't hear it that much with the iPhone recording, but here's the before idle:
And the after:
So, in short, if you run the NGKs you're a loon
This has been a not so important message from your mostly reliable Camaro brethren with too much time on his hands
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 07-20-2013, 01:10 AM   #2
injector
injector's Avatar
Drives: LS3
The difference is actually noticeable between the two videos.. Spark plugs do make a difference..
Texas Speed & Performance Custom Built Forged 408 CID, PRC LS3 260CC,Fast Intake & NW 102 TB, Alky Methanol kit, ID850, LPE Dual pumps,,Melling HV oil Pump. D1SC 10PSI, Stage 2 Air Intake,Magnaflow Axle back, Mcleod clutch, Pedders XA coilovers and sway bars, HD bushings, Hurst shifter, ACS bumper and hood ports, DSS aluminum drive shaft, CSF radiator .
injector is offline   Reply With Quote
Old 07-20-2013, 01:13 AM   #3
2SS45th
2SS45th's Avatar
I never thought so, but after swapping them I sure do.
Old 07-20-2013, 09:10 AM   #4
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
If you need to go even colder than the ZR1plugs, I'm having real good luck with Brisk GR12S plugs. They are really cold for nitrous and boost. The GR14S would be good for alot of boost or alot of nitrous. Normal size boost or nitrous and I too would run the ZR1 plugs.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 07-20-2013, 09:30 AM   #5
2SS45th
2SS45th's Avatar
I was running 2 steps colder, and I make 16 pounds of boost already. The ZR1 plugs are handling the boost better than the colder plugs at this point. Doesn't take a few cycles of cranking to start now either.
Old 07-20-2013, 10:51 AM   #6
dan0617
dan0617's Avatar
I wonder if I could get away with ZR1 plugs. 12 psi and now a 125 shot on top of it. Stock compression and stock L99 cam, 93 octane E10 no meth.
I have a feeling the ZR1's would be a little too high of a heat range, and since they are protruded they are not optimal for nitrous. Good for one or the other but not sure when running both nitrous and boost.
Old 07-20-2013, 11:15 AM   #7
2012REDSS
Drives: 2012 Camaro SS
sounds sick I used the ZR1 plugs too at 12 psi per Ted's recommendation
2012REDSS is offline   Reply With Quote
Old 07-20-2013, 11:15 AM   #8
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
br7ef if using nitrous. the thread cover the tip and helps with not blowing out the spark. i accually think my car runs and idles better with ngk's
ive got enuff plugs to run 10 cars a life time and swap them out quite a bit. i really like the br7 over anything else for nitrous on 100+ shot. but when it comes to blowers and plugs that i cant say nothing about.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 07-20-2013, 11:18 AM   #9
2SS45th
2SS45th's Avatar
You could definitely use the ZR1s with nitrous and a blower or only nitrous. I'm pretty sure Jamie also uses these plugs with his Maggie/Nitrous car.
Old 07-20-2013, 11:39 AM   #10
dan0617
dan0617's Avatar
I'm thinking about it. I was thinking they might be a little hot and being projected also, I was worried. Went with the NGK BR7's and had misfires at light throttle. Was going to go with Denso 22's, which are like NGK 7's, which are 1 step colder than the ZR1's and do not have a protruded tip, but couldn't find them anywhere. I went with Brisk 12's, which are a step colder than the Denso 22's. they are working good but likely colder than needed.
Just not sure if I should go with the ZR1's, the Denso IT22's, or the Brisk 14's.
At this point I'm still thinking I should avoid the protruded electrode of the ZR1 plug.
Decisions...decisions.
PS: I don't want to do what Jamie is doing, his car is slow. LOL
Old 07-20-2013, 11:43 AM   #11
dan0617
dan0617's Avatar
Thread covering the tip as you call it is what is called non protruded electrode. That is why I avoided the ZR1 plug in the first place, as they aren't optimal for nitrous. It's why I'm running Brisk silvers and considering the Denso IT22's. But most of my experience on plugs was with sbc engines and we are in a whole new world now with tuning and fine tuning.
Old 07-20-2013, 11:43 AM   #12
2SS45th
2SS45th's Avatar
I had misfires with the NGKs when starting, idling, light throttle, and returning to idle. I hated those plugs. I'd give the ZR1 plugs a shot, the $80 plugs made one of the biggest differences on a stupidly expensive car
Old 07-20-2013, 11:47 AM   #13
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
You said it idled better with the ZR1 plugs. With them being a step hotter then the BR7's would that be the reason it idles better?
Nitroman28 is offline   Reply With Quote
Old 07-20-2013, 11:47 AM   #14
dan0617
dan0617's Avatar
Your car sounds amazing by the way. Love it!
