Old 07-22-2013, 11:17 AM   #29
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
BR7EF plugs here for the last 3000 miles. My tuner highly recommended these plugs and loves to tune with them. Pat Guerra tuned the car. I have had not a single issue.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 07-22-2013, 11:44 AM   #30
Supercharged Red
Supercharged Red's Avatar
Drives: 2011 Camaro 2SS/RS A6 Victory Red
What is the number of the ZR1 plug? In other works what do I ask for at the Auto Parts Store?
2011 Camaro 2SS/RS A6/L99 Victory Red
SLP TVS2300 Supercharger 6psi & Coil Covers. Roto Fab CAI. RX Catch can ZL1 Fuel Pump
Kooks 1 7/8" LT Headers w/ High Flow Cats Corsa out the back! NT555R 305/35/20
472 RWHP 466 RWTQ 12.11 @ 114.3 MPH 1.81 60' Pacific Raceways Kent, WA 6/6/13
Supercharged Red is offline   Reply With Quote
Old 07-22-2013, 12:05 PM   #31
AngelSpeedFreak
Most hated in NM....
AngelSpeedFreak's Avatar
Drives: Sold the 6POINT2, went to a 50THZ06
Good info. Guess I will have to switch and give them a try. I also get some misfires on startup with the TR7's... Maybe the ZL1 plugs would help with that. Guess it's worth a shot for $80.
AngelSpeedFreak is offline   Reply With Quote
Old 07-22-2013, 12:07 PM   #32
Unreal
Drives: 2006 Z06
ZR1 plugs are good but for people pushing 850+ I think they are a bit too cold.
Nick
Corvette Z06 -1200ish rwhp
Old 07-22-2013, 12:27 PM   #33
CyberPredator
50 Shades of Prey
Drives: TT/SS
a bit to "hot"
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 07-22-2013, 12:29 PM   #34
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
ZR1 plugs are good but for people pushing 850+ I think they are a bit too HOT.
Fixed it for ya.
They are a 6 heat range by the number system we are all now used to. The NGK system, and others.
I'm thinking 600 or more at the wheels through an auto should be a 7 heat range and shouldn't be protruded if using nitrous.
I'm using an 8 right now and I think it is a little too cold. Not staying clean. Gotta find that balance between holding enough heat to stay clean, but not so hot at WOT that they melt, or cause detonation.
But some, like Jamie are having a ton of luck with the ZR1's at big power levels. Of course if he melts something he has enough extra parts to sell off and pay for a rebuild. LOL.
But what do I know, I'm still in the figuring and deciding process myself. Not the easiest choice to make.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 07-22-2013, 12:30 PM   #35
CyberPredator
50 Shades of Prey
Drives: TT/SS
Yea I ran those for 15000 miles with no issues. Tuned by Futral.
Old 07-22-2013, 12:33 PM   #36
LeanPocket
Drives: 2010 2SS
Originally Posted by H-E View Post
Go to the NGK website and educate yourself,after all why do the make colder plugs if one size fits all? I remeber when some were braging on running the stock plug and making 600 plus hp yada yada and as soon as the zl1 was out and GM used a colder plug,as they should since it went from 426hp to 580 those same guys jumped to the colder plug and braged about how it was so much better. Most dont understand what a plugs function is ,and its alot harder to tune a car with colder plugs so alot of shops run hotter plugs to make there job easier. Ive never put denzos in a car and not picked up power and the last a long long time.Good luck
This.
There are specific plugs with specific heat ranges for specific applications
LeanPocket is offline   Reply With Quote
Old 07-22-2013, 12:42 PM   #37
LeanPocket
Drives: 2010 2SS
with that said, the only way to tell if you have the proper heatrange is to check the plugs. There really is no all around plug for every aspect of ones application. ESP when you start messing with forced induction.
Old 07-22-2013, 01:08 PM   #38
Unreal
Drives: 2006 Z06
Yep, my bad. Too hot. Brain fart.
Nick
Old 07-22-2013, 01:14 PM   #39
pdiddy
Drives: 2011 2SS
I run the NGK TR6 I have not noticed any issues yet with them my tunner told me to run them so I did I am 90 percent sure he is also running an ngk not sure how cold and he is near 1100hp I was suprised when he said not to waste my money on the ZL1 plugs. I dont have an opinon as I have not run the ZL1 plugs but I am pretty happy with the NGK thus far.
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 07-22-2013, 01:17 PM   #40
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
I know JRE has pushed the ZR1 plugs past 800 before, and he highly recommends them as well. I thought the delayed starting was because of my injectors, turns out the plugs weren't getting the job done. Drove the car 60 miles yesterday and didn't have a so for stutter, cough, and it didn't search for idle either.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 07-22-2013, 01:39 PM   #41
se7en
Drives: 87 Pinto on 32's
Are some of you changing your plugs out at the track to a colder one to use with the blower and Nitrous and running a hotter one on the street to keep from fouling?
se7en is offline   Reply With Quote
Old 07-22-2013, 01:43 PM   #42
Ryne @ CMS
Ryne @ CMS's Avatar
Drives: 16 Camaro SS, 06 C6 Z06, 15 Sierra
this is my policy at the shop for FI apps:
up to 600rwhp zr1/tr6ix
up to 750 rwhp tr7ix
750+ tr8ix
mind you this is a general rule of thumb I very things from application to application... if I am hitting a car with a lot of nitrous we'll like move into a non-projected tip plug, but that doesn't mean I recommend them as a DD plug. cruising and 200+ shot of nitrous are two very different things.
Ryne @ CMS is offline   Reply With Quote
