Old 07-20-2013, 02:53 PM   #1
Homesickderf
Drives: Fast
Are front pirellis directional
I'm trying to find out before I purchase 1 from a forum member
Homesickderf is offline   Reply With Quote
Old 07-20-2013, 02:54 PM   #2
Midlife conVert
Drives: Black 2LT Convertible
No they only say outside on them Drivers and Passengers are identical.
Check out Alabama Camaros on Facebook! https://www.facebook.com/groups/173934389435353/
Midlife conVert is offline   Reply With Quote
Old 07-20-2013, 04:37 PM   #3
Denis
Denis's Avatar
Drives: 2010 SS
Pzeros are a directional tire. The front and rear are the same tire aside from the size.
Old 07-20-2013, 04:52 PM   #4
Midlife conVert
I think you may want to look again. Front and rear are different size but they only say Outside on them There is no arrow of direction. If you look at your left and right tire the tire would be the same if you put them side by side. i know on Tire Rack somewhere this will be verified!
Old 07-20-2013, 04:55 PM   #5
Denis
Denis's Avatar
Drives: 2010 SS
Yup...that would mean they're directional. Could be wrong but I don't think so. It says outside for a reason. Because it would guarantee they mounted correctly. Because they could get mounted backwards and therefore not be spinning in the right direction.
Old 07-20-2013, 05:33 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
They are absolutely not directional. Go look at your car and you will see that the tread slants forward on one side, backwards on the other.
The tires are marked "inside" and "outside", but not "right" and "left".
So you are wrong
Rock-It Man is offline   Reply With Quote
Old 07-20-2013, 05:39 PM   #7
stlrammer
stlrammer's Avatar
Drives: 2017 2LT/RS Yellow
I'm learning something new today. I always thought PZeros were directional as if I rotated left to right and right to left without remounting they would be going in the opposite/wrong direction even though they would both say outside.
stlrammer is offline   Reply With Quote
Old 07-20-2013, 06:12 PM   #8
Denis
Denis's Avatar
Drives: 2010 SS
So you are wrong
Okay. Go ahead and mount them so they rotate backwards when you're driving and tell me how you like them.
Old 07-20-2013, 06:26 PM   #9
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
Pirelli does make directional tires but the stock ones that come on our cars are not. They do have an outside and they do need to be mounted correctly. Outside of tire is marked, so you mount them on the wheels outside. When you rotate the wheels and tires, the outsides are still on the outsides. They do spin the opposite direction. But they are not directional so this is ok. The owners manual would not say to rotate side to side if they were directional.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 07-20-2013, 06:32 PM   #10
Denis
Denis's Avatar
Drives: 2010 SS
Oops. Guessed I haven't really checked out a set of pzeros recently.
Sorry for the misinformation.
Old 07-22-2013, 09:35 AM   #11
Jose
Jose's Avatar
Drives: 2010 Camaro 2SS/RS White S/C
So, if they are not directional, it would not make any difference if I mount one with the "outside" letters facing out and the other side facing in, correct?
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty
Jose is offline   Reply With Quote
Old 07-22-2013, 10:02 AM   #12
GMTool
MY SS is SOLD
GMTool's Avatar
The tires would roll just fine but handling/cornering would be screwed up. Not a good idea to do this. Designed for the outside to be on the outside.
Old 07-22-2013, 10:36 AM   #13
joeybsyc
joeybsyc's Avatar
Drives: 2010 Aqua Blue Metallic 2SS
Why would you want to mount them backwards anyhow?? They are marked inside and outside for a reason. If it didn't matter they wouldn't specify.
joeybsyc is offline   Reply With Quote
