BeckyD @ James Martin Chevy
Old 07-21-2013, 10:38 AM   #1
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
GM High Tech Performance Article
Great article on the Z/28.
Not sure if this is the current one, I'm in Afghanistan, August 2013 issue...
New Dif cooler that's integrated into a standard SS Dif cover...we hope to accessory to them as well, those SS and 1LE owners running at the track!
Springs and bushing increased spring rates 100-400 percent the rate!!!!!
Other great tidbits too.....
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 07-21-2013, 10:54 AM   #2
31B
31B's Avatar
Drives: 2014 Black 1SS A6
Send a message via Yahoo to 31B
Was there a link included?
31B is offline   Reply With Quote
Old 07-21-2013, 11:06 AM   #3
Synner
Drives: not stock
The Z28 will not use the SS diff, it uses the ZL1 rear with a different posi unit and I believe gear as well.
Old 07-21-2013, 11:47 AM   #4
SamHouseIII
I Carry!
Didn't say it uses the SS Dif...uses a cover that will fit the SS or 1LE, that has an integrated cooler on the cover!
Old 07-21-2013, 11:48 AM   #5
SamHouseIII
I Carry!
No link was included...just in the magazine...
Old 07-21-2013, 12:11 PM   #6
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
That's interesting. I'll have to keep that in mind.
Old 07-21-2013, 12:26 PM   #7
SamHouseIII
I Carry!
Here's is the part about the Dif cover..
Old 07-21-2013, 12:32 PM   #8
SamHouseIII
I Carry!
Spring and bushing rates...
Sorry it takes so long to post.....Internet is sucking over here.
Old 07-21-2013, 12:36 PM   #9
SamHouseIII
I Carry!
Last one.
Old 07-21-2013, 01:47 PM   #10
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
It appears to be the SS/1LE aluminum case with different limited-slip internals and cooling. Not the cast iron ZL1 case.
"Power is distributed to the rear wheels via a limited-slip differential featuring a helical gear set, rather than traditional clutch packs. The new design enables the driver to apply more power and get through corners faster, by continuously adjusting the torque bias to maximize available traction."
2cnd chance is offline   Reply With Quote
Old 07-21-2013, 05:32 PM   #11
Synner
Drives: not stock
Well that makes sense from a weight cutting standpoint, the ZL pumpkin is chubby. Its also good news because I can buy the guts and put it on mine. Although I'm concerned the torque biasing system is electronic and part of the "brain" of the car and therefore not going to be swappable. Stupid teaser press releases.
Old 07-21-2013, 05:53 PM   #12
2cnd chance
I think they were saying the cooling feature could be added to the SS and 1LE/SS.
I've read elsewhere the 3.91 ring and pinion were heat treated for additional strength.
Old 07-21-2013, 08:59 PM   #13
SEVEN-OH JOE
Drives: some to distraction
At no time, and in no place, did GM state the ZL1 carrier/diff was being used in the Z/28. In fact, it's been a recognized and stated fact here from March-forward that the 1LE diff/axle set-up was being used.
SEVEN-OH JOE is offline   Reply With Quote
Old 07-21-2013, 09:08 PM   #14
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
thanks for posting that!
backtotintops is offline   Reply With Quote
