Old 07-04-2009, 03:00 PM   #1
TomServo
Drives: 2007 Z06
Launch Control Demo / Information
As featured on homepage.
Watch Corvette enginers explain and demo launch control on a Z06
3.5 sec 0-60 is pretty decent.
TomServo is offline   Reply With Quote
Old 07-05-2009, 07:07 PM   #2
usmcjlp
Drives: 2SS/RS LS3 RJT
Thanks for posting, a picture is worth a thousand words.
usmcjlp is offline   Reply With Quote
Old 07-05-2009, 07:29 PM   #3
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Thanks Tom, that should help a lot of people understand the system. Nice find.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 07-05-2009, 07:41 PM   #4
badkarma
badkarma's Avatar
Drives: 2010 SIM 2SS Camaro
Cool info, good stuff to know before I try it ... soon.
Ok, so who else noticed that most of the audience was older gentlemen either balding or grey hair or both?
badkarma is offline   Reply With Quote
Old 07-05-2009, 07:44 PM   #5
Steve
Ancalagon The Black
Steve's Avatar
Drives: 2004 Silverado 4X4, 2010 RJT 1SS
Great video. I tried Launch Control the first week I got the car and was not able to get it to limit at the 4,000 RPM they speak of. After trying the throttle twice and having it go to 7,000 RPM I quit so I would not hurt the engine. I thought I would wait until I had 1,500 miles on the car before I would try it again. I had the DIC display Competitive Mode. What is the trick?
Steve is offline   Reply With Quote
Old 07-05-2009, 07:53 PM   #6
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Very cool and informational video.
Old 07-05-2009, 08:04 PM   #7
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Hold the traction control button down for 7 seconds. It should turn off the traction control and stability track. You will see both lights in the tach stating they are both off. Try it then.
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 07-05-2009, 09:02 PM   #8
LDGn63
LDGn63's Avatar
Drives: WNABEE
i did the same thing.
in my case, i was being too gentle on the gas pedal... seriously!
here is how i goes:
double click the traction control button
"competitive mode" will show on DIC
from a COMPLETE STOP, clutch to floor, put it in 1st, put the gas STRAIGHT to the floor (do not hesitate)
the revs should stop at about 4200 and hold until you drop the clutch... keep your foot ON THE GAS.
(BTW, holding the button down for 7 secs turns EVERYTHING OFF... launch will NOT work this way)
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Old 07-05-2009, 09:18 PM   #9
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
LC is for showing off, not 60 footing. It might make you more consistant, but it's certainly not the key to the best ET.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 07-05-2009, 10:10 PM   #10
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
Nice vid, Thanks
69 Hugger is offline   Reply With Quote
Old 07-06-2009, 08:31 AM   #11
TomServo
Drives: 2007 Z06
They beat the factory 0-60 rating of 3.6. So how is that showing off. Plus the fact it's easier on the drive train. Maybe you need to re-watch and listen to that video again.
I'd say "not using LC" is showing off since the vast majority of M6 SS owners won't be able to master the art of launching the car w/o distress.
Old 07-06-2009, 02:16 PM   #12
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
Did you see the amount of wheel spin? That is not how you cut good short times. Launching well involves dead hooking. But what do I know, I only have a couple hundred passes.
Old 07-06-2009, 05:19 PM   #13
CGM2SSRS
susp.ban4life!
CGM2SSRS's Avatar
Drives: Raptor
+1
CGM2SSRS is offline   Reply With Quote
Old 07-06-2009, 06:21 PM   #14
Stooph
Stooph's Avatar
Drives: 2010 CGM Camaro 2SS
Ok so I'm going to be a total girl right now (good thing I am one) but does launch control come on both the V6 and V8s? or only one?
Ordered: 26Jun2009
Built: 09Sep2009
Delivered: 21Sep2009
2010 2SS Cyber Grey Metallic Camaro
Stooph is offline   Reply With Quote
2010 Camaro Launch Control = Transmission Failure camaroguy Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 140 07-06-2013 12:27 AM
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 02:12 PM
Camaro SS Launch Control jdpickering Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 35 12-23-2009 10:29 AM
COMPETITIVE MODE AND LAUNCH CONTROL (V8) DIRECTIONS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 80 05-02-2009 01:20 PM
"CAMAROS" Row after Row @ Oshawa Plant Lot...IT Must Be In Production!?? Elvisuperman Camaro Photos | Spyshots | Video | Media Gallery 265 03-16-2009 09:40 PM
