Old 07-22-2013, 10:57 AM   #1
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Another exhaust upgrade...now done with exhaust
I already had Solo HFC, Magnaflow Tru X, and Dynomax VT mufflers on the car, but the pipe going from the X to the Dynomax was still the stock 2.25" with stock resonators on it. Friday i had to have a sensor installed for my AFR gauge and while it was on the rack i had the muffler shop replace that portion of pipe with 2.5" without resonators. I was worried the noise level would be bad, but found it to be just fine plus i picked up the benefits of the better flow. My midrange feels a little better as well. Now the whole system is 2.5"
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is online now   Reply With Quote
Old 07-22-2013, 06:15 PM   #2
Niko
Treasure Coast Camaro 5
Niko's Avatar
Drives: Black Camaro LFX
Was there a increase in sound at all when you knocked the resonators out.
Did you install everything at once or one at a time, if you did it one at a time did the tru X make a difference with it as well
Niko is offline   Reply With Quote
Old 07-22-2013, 06:46 PM   #3
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
Nice, congrats! Exhaust is probably the next thing I'll be tackling with my V6
Aubrey64 is offline   Reply With Quote
Old 07-22-2013, 08:45 PM   #4
IneedAZ
IneedAZ's Avatar
First I did the mufflers, then I did the converters and xpipe, and now the pipe from the x to the mufflers. Since the x and converters were done together I cannot say how much one did over the other. Now that all is done I can say I don't notice anymore drone then the mufflers by themselves. There was a slight increase in sound after doing the x and converters, but not the annoyance inside the car. If I had the money to waiste I would try a couple other mufflers to see how they sound and perform to what I have.
Old 07-22-2013, 08:57 PM   #5
Niko
Niko's Avatar
Ok I have magnaflow mufflers with a secondary cat delete. It's quiet when just driving around town but once you hit pass 3k it's a different story. It really wakes up and sounds nice. I'm just trying to figure out to make it louder.
Old 07-22-2013, 09:45 PM   #6
IneedAZ
IneedAZ's Avatar
Converters and Tru x will give it a little more sound
