Emblempros
Old 07-22-2013, 01:25 PM   #1
jake2212
jake2212's Avatar
Drives: 2010 camaro 1ss/rs A6 Supercharged
i hope this isn't normal
hi everyone, i recently noticed on my car that it looks like the door is either pushed in, or the rocker is coming slightly out. i wanted to know if this is normal or if i should have this looked at. also if this would/should be covered under warranty because this should not be happening on a car this new. pics attached
Check out my build thread: Project Ultimate Street Camaro
http://www.camaro5.com/forums/showthread.php?t=378443
jake2212 is offline   Reply With Quote
Old 07-22-2013, 01:37 PM   #2
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
That's how mine is.
GM fit and finish leaves a lot to desire.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 07-22-2013, 01:39 PM   #3
AZSS6SPD
AZSS6SPD's Avatar
Drives: 2010 1SS (HIS&HERS)
The rocker panel needs adjustment. Check and see if you have some play. Should be a simple fix.
AZSS6SPD is offline   Reply With Quote
Old 07-22-2013, 01:55 PM   #4
JewelSS
Norcal Camaros
JewelSS's Avatar
Drives: 2010 Red Jewel 2SS L99
Needs to be popped off and adjusted. if you feel comfortable do it yourself....
Fire Extinguisher, AAC footwell lighting, Switchback LED's, AAC Mailslot scanner, AAC underhood, grill & underbody led lighting, AAC Plasma fogs, Eagle eye HIDs, RJT Painted calipers, RJT painted engine bay, Viteese Paddle Shifters, CFD Hurst style Shifter, RJT painted speedo & gauge trim, RotoFab CAI, TSP 2" Headers with full 3" XS Power exhaust, 275's all around, Granatelli Slotted rotors & Hawk HPS pads, ACS Side Rockers, ACS Front splitter, ZL1 Grill, Havoc Rear diffuser, BMR 1.4 Springs, BMR Strut tower brace, BMR F/R Sway Bars, BMR Trailing Arms, Custom Tune by Starkweather Performance
JewelSS is offline   Reply With Quote
Old 07-22-2013, 03:24 PM   #5
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Mine are a nightmare. Worse than that. I should take some pics one of these days.
[B]
Old 07-22-2013, 04:14 PM   #6
jake2212
jake2212's Avatar
I'm takin mine to the body shop at the dealer on Wednesday.
Old 07-22-2013, 04:38 PM   #7
Chevrolet Customer Svc
Drives: GM Vehicles
jake2212,
I appreciate the update you provided, saying you will be seeking service on Wednesday. Please let us know how your visit goes. If you need additional assistance, don't hesitate to message us privately.
Sincerely,
William R.
Chevrolet Customer Care
Chevrolet Customer Svc is online now   Reply With Quote
Old 07-22-2013, 04:47 PM   #8
POWERMAN
POWERMAN's Avatar
Drives: '13 Charger Sxt+
And I thought the Chargers had it bad..
I raised a similar issue up @the dealer and they took me around the lot to look at the new ones.
A lot of them had mis-aligned panels that looked worse than mine (although they were nice enough to give me a rental while my doors were being re-aligned at the body shop.
I had to spend a good 2+ hours with them to prove my point (even showing how each door made a different sound when closing)
Seriously, I dont understand how the folks over at Brampton (Chrysler plant) and Oshawa (GM plant) allow these vehicles to pass final inspection after assembly..
POWERMAN is offline   Reply With Quote
Old 07-24-2013, 03:25 AM   #9
jas81363
Drives: 2013 Camaro 1SS/RS M6 Blue Ray
mine is like that to.
jas81363 is offline   Reply With Quote
Old 07-24-2013, 06:22 AM   #10
bkdamon
bkdamon's Avatar
Drives: Rally Yellow 2012 1LT
Mine aren't that bad but it is noticeable. Check out how they install, remove and reinstall the doors. The only QC inspection they show is for leaking, maybe more was done off camera but it's not enough for sure.
How your Camaro was built
bkdamon is offline   Reply With Quote
