Old 07-09-2009, 11:32 AM   #15
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Anybody know if there is a TSB/fix for the misaligned body & door panels yet (like what VIN #1 had that became a big fiasco of a discussion on here)?
fldrummer is offline
Old 07-09-2009, 11:33 AM   #16
fldrummer
"Black Ace"
fldrummer's Avatar
Originally Posted by croyal1974 View Post
My problem:
1. Drivers side roof light( the one with the toggle switch) only works when its toggled over to the passenger side.
I have that problem too, if it is one. I was starting to think that was just the way it was designed (?).
Old 07-09-2009, 11:35 AM   #17
CmB
OMG Bumblebee!! UM NO!!
CmB's Avatar
Drives: IMO 2SS RS LOADED!
I would add
1. Alignment of doors to dash interior the door interior seems to sag below the dash interior
2. Door sill decals peeling up
Thanks for starting this thread. Very helpful.
Vroom, Vroom, see ya later Mustagator!!
CmB is offline
Old 07-09-2009, 11:42 AM   #18
RobSilverTA
Rob
RobSilverTA's Avatar
Drives: 2010 SS/RS Chevy Camaro
Paint issue
When I picked mine up, there was a small paint swirl in the passenger door. They had to send it out to be repainted. It looks good now though.
RobSilverTA is offline
Old 07-09-2009, 12:52 PM   #19
aldaran
aldaran's Avatar
Drives: 2016 Camaro 2SS/RS
Originally Posted by Teccboxx View Post
I am still trouble shooting my problem, it was believed to have a bad fuel sensor, they replaced that and still didn't fix the problem. They now believe it is a programming problem as they checked all the wiring. So it is going back to the shop next monday.
(Problem) The gas gauge is all over the place, sometimes full, sometimes empty, you can drive down the road and it says helf full then it reads 3/4 full. It isn't effecting the drive or anything just an annoyance and remembering to keep the tank full.
My Silverado had/has that issue. Gage went to 3/4 when I just filled it at the gas station. It then moves around when stopped. Dealer replaced fuel level sensor twice indicating it shorted out. I don't know why, but I feel like it will happen again. My 2000 Camaro also has the same problem but ran out of warranty when it started so I started using the trip/odometer just in case its wrong. If I throw in a Fuel Injector cleaner into the tank it starts to read correct for about a month and will start again. Weird.
aldaran is offline
Old 07-09-2009, 01:00 PM   #20
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Need to add non RS taillights installed on RS equipped cars. I've seen 2 like this so far, mine and the SS/RS Camaro my dealer received after my Camaro. Ed M.
flht99b is offline
Old 07-09-2009, 01:39 PM   #21
ssrsheaven
ssrsheaven's Avatar
Drives: 92 firebird,2010 camaro
Originally Posted by broncosman View Post
Ultimate Checklist for Dealership inspection B4 U pickup.
Can we get a master list going of all the things people found wrong with the car that QA missed? Let's keep the list down to just the facts. One of the more common issues found is loose bolts that hold back some type of fluid (ex: oil). I'll try and go through the posts and edit this post adding everyone's item making a master list people can print out to take with them and have checked out before they take the ride home. Should help everyone and I hope everyone can chime in here. Especially those that have their ride already and experience problems. Also, pls correct me if I have any mistakes in the list. Thanks.
The list:
__________________________________________________ _________________
001. Loose Bolts that hold fluid back (ex: on oil pan)
002. Trunk Locking mechanism (issues with opening w/o adding down pressure to top of trunk first and/or emergency release appears to be loose keeping the trunk from locking properly) (also check the trunk monkey, free food for first month).
003. Loose plastic panelling around the 4-gagues cluster, launch control, and cigarette power plug as well as Left and Right A-Pillars Trim Loose.
004. Loose Spoiler.
005. Wiper transmission cable overheating from engine causing a shortcircuit.
006. Matching Headlight Halos strength. (one defective being dimmer then the other).
007. Mismatched paint on parts of the vehicle. As well as paint runs or clear coat runs.
008. Loose Rocker Panel "Chevrolet" causing it to peel off.
009. Minor Problem With Window Indexing.
010. Ambient Lighting on doors defective.
011. Bad radiator (leaks)
012. Hood release/latch issues (won't unhook to open the hood)
013. Gap at base of ONStar Antenna
014.
Thank you for the list
ssrsheaven is offline
Old 07-09-2009, 01:42 PM   #22
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
I would add all those having the shaft cracking when dropping the clutch.. There iis a thicker camshaft being installed for them..We need a part number of the newer more thick shaft since we all should have it replaced and installed ASAP..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline
Old 07-09-2009, 02:06 PM   #23
cobra
cobra's Avatar
Drives: 69 Z28
Don't forget to ask if the recall issue involving the battery cable routing near the starter has been done,
cobra is offline
Old 07-09-2009, 02:09 PM   #24
96rss/ls6
Inferno is the only color
96rss/ls6's Avatar
Drives: 96 ls6 camaro, iom 2ss/rss /
Dude what are you talking about. Replacing a camshaft? Im confused how could you crack a cam? do you mean the driveshaft, and if so whats up, I havent heard about this.
96rss/ls6 is offline
Old 07-09-2009, 02:17 PM   #25
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
it is the driveshaft connection to the diff.... supposodly only for VIN's in the 16000's
UCF w00t compiled a list of 4 cases of this ... all in the 16000 -17000 VIN range
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline
Old 07-09-2009, 02:21 PM   #26
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2018 Silverado
#4 needs to be edited... should say... Re-torque Spoiler bolts... Most of them still feel tight yet the bolts are waaaay loose...
mlee is offline
Old 07-09-2009, 02:47 PM   #27
logan1080
logan1080's Avatar
Drives: 2003 Crew Cab Duramax
I was very mad when I heard my car is stuck in quality control. Now I am somewhat happy it is haha.
logan1080 is offline
Old 07-09-2009, 03:09 PM   #28
bumblebee rules
bumblebee rules's Avatar
Drives: 2010 BumbleBee ready to go now
Mine showed up with a scratch on the front window pillar on the drivers side, the yellow does not match on the mirrors .... no other issues
bumblebee rules is offline
GM dealership customer service and sales HPlover Camaro Price | Ordering | Tracking | Dealers Discussions 15 04-01-2014 11:48 AM
CAMARO DELIVEY CHECKLIST / DEALERSHIP REQUEST FORM CamaroScotty Camaro Price | Ordering | Tracking | Dealers Discussions 78 11-23-2010 05:21 PM
Dealership issues...Any constructive input would be helpful achalk Camaro Price | Ordering | Tracking | Dealers Discussions 7 03-16-2009 11:42 AM
