BORLA
Old 07-09-2009, 03:13 PM   #29
Mohrg Beast
TURBO HUNTER!!!
Mohrg Beast's Avatar
Drives: 2010 Camaro Lt Vin #1974
a ton of stuff in my interior was just falling off..lol..the hood latch under the steering wheel is very cheaply made..very cheaply..since day one you can pop the hood and look at it and it just dangles there.hanging by its wire. bs if you ask me. also some of the interior trim on the side of the windshield the big main piece between the windshield and the door glass. was just barely hanging there..lastly my consol where the usb plug in is is insanely cheaply made..it has a basic cut in the plastic for the latch to latch to instead of an actual latching mechanism.for this to be a high end GM car it should be made a little more high end..guess they knew people would be more excited about the exterior and motor than the interior.
Mohrg Beast is offline
Old 07-09-2009, 03:16 PM   #30
Mohrg Beast
TURBO HUNTER!!!
Originally Posted by Teccboxx View Post
I am still trouble shooting my problem, it was believed to have a bad fuel sensor, they replaced that and still didn't fix the problem. They now believe it is a programming problem as they checked all the wiring. So it is going back to the shop next monday.
(Problem) The gas gauge is all over the place, sometimes full, sometimes empty, you can drive down the road and it says helf full then it reads 3/4 full. It isn't effecting the drive or anything just an annoyance and remembering to keep the tank full.
im not a mechanic or anything..but it may be as simple as the floater in the gas tank screwed up..have they tried that..or it just may be floating period, or sticking.to me thats what it sounds like. i had an 08 tahoe with a full tank read empty and turn the empty lights on at a certain degree incline.
Old 07-09-2009, 03:21 PM   #31
Mohrg Beast
TURBO HUNTER!!!
Originally Posted by fldrummer View Post
Anybody know if there is a TSB/fix for the misaligned body & door panels yet (like what VIN #1 had that became a big fiasco of a discussion on here)?
something to think about if you get racing stripes..have your painter to measure the stripes out from a neutral point..and not use the center of the hood..my hood after inspection was real close to the car on one side and way far off on the other..well compared to each other that is..anyway it was giving a hell of a time to my painter..we ultimately just had him to use his own centering to make sure the rest of the car would match up..otherwise the top stripes wouldnt have matched up whatso ever..but dont guess that matters to those of you just getting hood/truck stripes..but still something to think about nontheless.
Old 07-09-2009, 04:36 PM   #32
Drive fast, take chances
Driving Camaros 40 yrs
Drive fast, take chances's Avatar
Drives: 70 Z28/RS, 99 SS, 2010 2SS/RS w/SC
Nicked wiper wiring
Wiper motor wiring comes thru bottom of the cowling-well in front of the driver. There is a rubber grommet around it that sticks up 2 -3" causing the wiring to be too close to the wiper drive plate before it turns horizontal to go to the wiper motor. On my 2SS/RS it pealed the cover and the insulation off the wires in the first 10 minutes of running the wipers and then arced to the drive arm and blew the fuse.
The fix (decided upon between the dealer and myself) was to re-insulate the wires, cover the harness with a hard, slick plastic covering, drill a small hole in the bottom of the cowling-well (fill the hole with silicone) and use a cable tie down like the rest of the wiper harness uses to secure the harness to the floor of the cowling (the grommet will collaspe downward with little force), far away from harm from the wiper arms.
You can see this grommet thru the slits in the cowling, make sure yours is far down in the well and away from the moving wiper parts.
Drive fast, take chances is offline
Old 07-09-2009, 04:46 PM   #33
The gas gauge reading at various levels is most likely a short in the power wire to the sender unit, probably above the tank and probably a small crack in the insulation that only causes a short intermittantly when the car is moving.
Does the gauge change when the car is not running (key on) and sitting still?
My 2001 TA had this problem, hard to find but easy to fix.
Old 07-09-2009, 07:28 PM   #34
broncosman
broncosman's Avatar
Drives: 2010 Camaro 1SS
Send a message via Skype™ to broncosman
The list is updated and I also made a printable checklist in Excel & Word formats.
2SS/RS with painted Rally Stripes
http://www.h-towncamaroclub.com/index.php
broncosman is offline
Old 07-09-2009, 07:51 PM   #35
BLACK10
BLACK10's Avatar
scraping sound for a second when backing up(manual 6 speed)
BLACK10 is offline
Old 07-09-2009, 07:51 PM   #36
Purdue2011SS
Boiler Up!! POTFH
Purdue2011SS's Avatar
Drives: 2011 2SS/RS IOM Camaro
engine makes continous clicking noise, starting roughly 5 seconds after engine starts, along with "squeky brakes" that was already mentioned before (these are on the 1LT/RS automatic)
Purdue2011SS is offline
Old 07-09-2009, 08:48 PM   #37
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
I think some of the items on the updated list are duplicates
016. Pully shaking.
037. Bottom pulley shakes and needs replacement per dealer. Will post video tomorrow.
027. Shift knobs wearing out extremely fast could be faulty material
039. Shift knob material wearing...
028. AC system stops blowing cold air in random durations, most likely blockage in AC drainage
050. AC draining into the car instead of beneath it
031. USB/aux work
042. USB drive and aux port works
slick rick is offline
Old 07-09-2009, 09:18 PM   #38
broncosman
broncosman's Avatar
016. Pully shaking.
031. USB/aux work
Fixed & updates. Ty
Old 07-09-2009, 10:51 PM   #39
SummoneR
Paul
SummoneR's Avatar
Originally Posted by bumblebee rules View Post
Mine showed up with a scratch on the front window pillar on the drivers side, the yellow does not match on the mirrors .... no other issues
Oh man you fixed the typo... I was going to ask... did you mean Scratch or Crotch (not Cratch as originally stated). Either way that's not good, unless the later was a hot babes!
Great thread BTW!! I will have to print this out when I go to pick mine up!
SummoneR is offline
Old 07-09-2009, 11:05 PM   #40
OldSchoolCamaro
Living the American Dream
OldSchoolCamaro's Avatar
Drives: 2010 Camaro RS/2SS Rally Yellow
trunk gasket at bottom of rear window coming off
Paint chipped on driver door (might have been dust in paint). Dealer won't repaint whole door since yellow is too hard to match. Ordered touch up paint :(
Gas fill door different color than rest of car on Rally Yellow (paint mismatch already mentioned in item 7).
Aux and USB ports don't show up on radio as a selection 20% of the time.
Dash on driver's side lower than door trim (opposite issue of 52)
In addition to the above items, I have seen 2, 7, 29, 32, 37, 54 on my car. Rear window trunk gasket, sill stickers and dash alignment are being fixed today and tomorrow.
Rally Yellow 2SS/RS w/Cyber Gray Stripes
Customer pick-up: June 17 2009
C5 Indiana Camaro Club
Central Indiana Camaro Club
OldSchoolCamaro is offline
Old 07-09-2009, 11:10 PM   #41
Mohrg Beast
TURBO HUNTER!!!
ive had two brand new cars in the past two years..the brakes squelled very harshly for about a week..cause they were new..they had the EXACT same sound as bad breaks or very very worn out brakes..after a few days..nothing, so before you get madder than hell give it about a week if you dont drive it alot or a couple of days if you do. mine did the same exact thing when i got mine in may. three days later perfect.
Old 07-09-2009, 11:29 PM   #42
anthonybyram
anthonybyram's Avatar
Drives: 1972 Z28, torch red,454
Big Thanks Broncosman! Ran off a copy for when mine gets here! GREAT IDEA!
anthonybyram is offline
GM dealership customer service and sales HPlover Camaro Price | Ordering | Tracking | Dealers Discussions 15 04-01-2014 11:48 AM
CAMARO DELIVEY CHECKLIST / DEALERSHIP REQUEST FORM CamaroScotty Camaro Price | Ordering | Tracking | Dealers Discussions 78 11-23-2010 05:21 PM
Dealership issues...Any constructive input would be helpful achalk Camaro Price | Ordering | Tracking | Dealers Discussions 7 03-16-2009 11:42 AM
