Jason 98 TA
Old 07-24-2013, 10:38 AM   #1
Kakashi
Drives: Camaro SS 2010 M6
Considering Meth, opinions welcomed!
So far I'm pretty happy with my setup, but want to see if I can squeeze a bit more out of it.
Power Mods:
P1SC-1 @ 7.8psi (4.0 pulley)
1 7/8 LT Headers
Fuel:
ZL1 Pump + ADM FPCM + DEKA 107962 Injectors + ZR1 MAP
Motor:
Completely stock LS3
I am currently at ~545rwhp @ 6400rpm | 7.8psi /w 93 fuel and ~585rwhp /w 100 fuel. But my IAT's are on the high 160's
I am considering (well, I am past considering, i *want* it and *getting it* ) adding a Meth Kit not only as protection/cooling the charge, but also to grab a few more ponies in the process. Would hoping for ~600rwhp on 93 be too wild of a hope or 625-640rwhp on 100 fuel.
I keep hearing good things about the Alky Meth Kit, and was hoping to pair it with the AIS Trunk Tank (if I can find a vendor that would sell me this mix as a kit)
Questions:
Would I need a single or dual nozzle?
Would it better / simpler / safer to run it from MAF or from Boost?
Would the best setup be Supercharger > Intercooler > Meth > IAT > TB?
Any benefit of going full meth vs a mix with water?
Kakashi is offline   Reply With Quote
Old 07-24-2013, 01:12 PM   #2
BLACK10
BLACK10's Avatar
ALKY two nozzle setup with map/boost activated. nozzles have to be after the MAF.
Old 07-24-2013, 01:18 PM   #3
Joe@CPR.com
Joe@CPR.com's Avatar
Drives: 03 vette, 94 trans am, 04 gto
a dual will work but would probably be overkill for your situation. have it come on at a set boost level, post maf and make sure to run an iat sensor post meth nozzle.
go Supercharger/intercooler/maf/meth/iat/tb
we carry the full ecs line so could set you up if you want.
Joe@CPR.com is online now   Reply With Quote
Old 07-24-2013, 01:19 PM   #4
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
I am running AEM meth kit with one 550cc nozzle on a progressive boost switch - starts ~4psi -> full flow @ 10psi
it brought my IAT's from over 200+ degrees in 90degree weather down to 130 at the most. But when weather is around 70 degree i was seeing about 80-90 degree IAT's.
my car before meth produced 622whp/598tq
next year i will be running a second nozzle as i will be shooting for over 900whp
xjer22x is offline   Reply With Quote
Old 07-24-2013, 02:53 PM   #5
SIC-PERFORMANCE
SIC-PERFORMANCE's Avatar
Drives: SLOW.
how much boost, what type of forced induction and whats done to the motor man?
SIC-PERFORMANCE is offline   Reply With Quote
Old 07-24-2013, 03:05 PM   #6
xjer22x
xjer22x's Avatar
well it was a rear mount twin turbo setup. I ran around 9-9.5psi at the track. and the motor was completely stock.
cylinder 7 gave up on me at the track so i am in the process of rebuilding the motor.
Most likely going with stock displacement and stock crank with all forged internals. The plan is to run ~16psi on the street and ~20psi at the track.
Old 07-24-2013, 04:31 PM   #7
blake-b
blake-b's Avatar
Drives: Black 2010
I heart Meth. I made 825rwhp at 15# with a Ysi before meth. I added meth, cam, and 5# of boost. I don't know what I make now but it is more. Car isn't tuned for meth, just there as a safety factor.
However, I am changing to twin turbos and keeping the meth. I am hoping to hit 4 digits on rwhp before I break something.
I have an alky control kit with dual M10 nozzles and using their 4 gallon trunk kit.
Here is a pic of the tank. Install wasn't completely done when taken but that is where it sits. There is no sight reservoir to see how much is in it but it comes with a red LED that lights up when low because it comes with a low lever sensor. The white LED changes illuminates red as meth is being pumped and changes to green with fully pressurized and pumping. If I am not under boost and there is plenty of meth in the tank, neither come on.
Old 07-24-2013, 06:49 PM   #8
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Blake, what turbos are you gonna run? Inquiring minds need to know.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 07-24-2013, 10:33 PM   #9
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Alky Control is the way to go. You only want a single nozzle for that power level. If you call Julio at Alky Control he will answer all your questions, and he knows his stuff.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 07-24-2013, 10:53 PM   #10
2010Slowmaro
5.0 lol...
2010Slowmaro's Avatar
Drives: 2010 Camaro 2SS M6
Agree with everyone else. Alky Control ftmfw.
2010 2SS M6 SWG built turbo car
2000 Z28 A4
Custom tuned by a Skinny White Guy
2010Slowmaro is offline   Reply With Quote
Old 07-24-2013, 11:36 PM   #11
BLACK10
BLACK10's Avatar
Do it once and put two nozzles incase you go with more hp in the future. EVERY boosted car we do has two nozzles. The alky kit has a gain knob on it. Just because you run two nozzles doesnt mean you have to over spray it. As always its in the tune.
Old 07-24-2013, 11:44 PM   #12
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
+1 and Julio custom builds his kits to your specs, so no need to get another brand trunk tank. I'm at 707 rwhp and the ALKY kit is the shit!
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 07-25-2013, 05:38 AM   #13
realcanuk
realcanuk's Avatar
I don't agree with this. Adding the second nozzle later, if needed is simple and very inexpensive. If you have too much nozzle, and run the gain control too low, you will have issues.
Its your car and money, so I'll repeat, call Julio. Get the answers from the experts, when ever possible.
Old 07-25-2013, 07:04 AM   #14
grocerygetter
instigator
grocerygetter's Avatar
Yeah...Alky Control. For sure. Ask Julio about single vs dual...he will be straight up and tell you what you need.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
