Old 07-25-2013, 01:19 PM   #15
BLACK10
BLACK10's Avatar
Originally Posted by realcanuk View Post
I don't agree with this. Adding the second nozzle later, if needed is simple and very inexpensive. If you have too much nozzle, and run the gain control too low, you will have issues.
Its your car and money, so I'll repeat, call Julio. Get the answers from the experts, when ever possible.
i was just going off of the dozens and dozens of alky systems i have installed and we have tuned here at Lethal.
Old 07-25-2013, 01:22 PM   #16
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
I didn't meant to upset you and I know you know your stuff.
I just know that at 550hp, a dual nozzle is overkill and I personally know of cases where running the gain too low (under 4 if I recall) can cause problems with the system.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 07-25-2013, 01:32 PM   #17
BLACK10
BLACK10's Avatar
nah, its not like that.
what i meant is that when we did do one nozzle installs it always turned out that the customer came back later for more hp or, the one nozzle didnt drop the iat's down enough to help out the pulling of timing.
Old 07-25-2013, 02:51 PM   #18
Birm
Birm's Avatar
Drives: Florida Speed & Power
Alkycontrol for the win. single nozzle will be more then enough for your setup but as Black10 said, a dual while you're in there is worth it since no one ever has enough power. As long as you keep the gain at the appropriate level and the tune is $$$$ you will not have any problems.
Let me know if I can help you in anyway in getting your Alky kit or if you have any questions feel free to ask.
Birm is offline   Reply With Quote
Old 07-25-2013, 07:04 PM   #19
realcanuk
realcanuk's Avatar
Ok... Just do the dual if you feel the need. As long as you use Alky Control.
I was single nozzle at 600 rwhp. When I changed to dual, it cost something like 40 bucks for the kit and I had to waste a half hour adding it.
Old 07-25-2013, 09:54 PM   #20
Inferno LSX
Supercharged LSX
Inferno LSX's Avatar
Drives: 2011 2SS/RS Black/Carbon Fiber
Meth is a must!
Inferno LSX is offline   Reply With Quote
Old 07-26-2013, 08:18 PM   #21
Kakashi
Drives: Camaro SS 2010 M6
Thanks for the info / help I'll keep it all in mind and get in contact with Julio @ Alky. I'll see where I go from there on what to buy for my goals.
Kakashi is offline   Reply With Quote
Old 07-26-2013, 08:37 PM   #22
SmokedSS
Guest
Drives: 2011 2SS / RS A6
Alky Control, installed @ 497 RWHP with no issues and have since move up to 652 RWHP and still working great! May as well start with dual because you will end up there. We all do
SmokedSS is offline   Reply With Quote
Old 07-27-2013, 04:28 PM   #23
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
Dual nozzle Alky Control is the way to go.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 07-29-2013, 08:54 PM   #24
quincy speeder
Drives: 2011 Camaro SS
Alky control works. Still haven't hurt my motor yet.
2010 SS, 230 Cam, ARH headers,Airaid intake, 160 t-stat,3.90 gears 475hp/430tq. -old setup
added- Procharger F1-D, alky control,FIC 96lb,fuel system- 810hp/735tq- 10.3 at 136mph , 1.75 60'. see how long it lasts.
Thanks to Slowhawk Performance.
2008 C6, 427ci,YSI,mcleod clutch,Alky control, built tranny, custom fuel system. 985rwhp, best 1/4 -9.4 at 152mph. still trying to get the shifting down:(
quincy speeder is offline   Reply With Quote
Old 07-29-2013, 09:35 PM   #25
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
And it never will
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 07-29-2013, 11:16 PM   #26
Deezee
Drives: 2013 SS/RS
Ecs 1500 kit+nf cam+1 7/8 LTs+alky dual nozzle made 750whp in my c6 at lethal. We pulled a little timing (to save the stock clutch) and I dd 701whp! meth? Yes please!! Was at 650whp before it
Deezee is offline   Reply With Quote
Old 07-30-2013, 10:25 PM   #27
CamaroSS45
Annihilator
CamaroSS45's Avatar
Drives: 2012 45th ERL-427 F1X
Curious how much fuel you are having to pull in this / similar setups to avoid going too rich (impacting HP) and then as a result being so heavily dependent upon meth as a fuel source that any failure could cause a lean situation....
Could you comment on how you are addressing your tune here? .... I, like many, really want to leverage meth as a cooling and for the safety elements it offers so well - but not to the point I must pull fuel due to being so rich and then have potential risk. I don't even want to add timing with meth ....
Thanks for the insight from all the smart folks here....
ERL M3 Superdeck 427 Forged, Dragon Slayer Crank, Black Label Heads : ProCharger F1X Cog - Holley HighRam : Jakes4L80e CircleD - DSS 9" 1400 axles/shaft, BMR Suspension : Extreme Innovations 15 : Squash, Bosch 127lb FI : ALKY Twin Meth
CamaroSS45 is offline   Reply With Quote
Old 07-31-2013, 09:06 AM   #28
Deezee
Drives: 2013 SS/RS
You would have to contact Shawn or nick at lethal racing for the tuning details. I do know they mounted the IAT sensor after the meth nozzles and the tune was set up so if it saw a large increase in temp (indicating no meth/bad pump ect) then it would pull all the timing and save the motor. That's how most do it I believe. Maybe one if them will chime in and give you more details. I personally see no problems with tuning the meth for power as long as there are safeties in place. I also had a light nick mounted by my boost gauge to tell me when the pump was on (red) and when I was at full psi (green) hope this helps.
