Cold Air Inductions
Old 07-24-2013, 05:51 PM   #1
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
ZL1 rearend noise bulletin
Here is an excerpt from the bulletin.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Some customers may comment on a moan noise from the rear axle during cold start turning maneuvers. In some instances the noise has been described as coming from the front of the vehicle. The noise may start to be noticed as the vehicle accumulates over 3,000 miles.
Recommendation/Instructions
Note: Steps 2 – 9 MUST be performed two (2) times for a total drain and fill of three (3) times to have this procedure be effective.
1. With original lube in axle, conduct Freeway Speeds for 10 miles to warm up lube.
2. Immediately drain original lube and refill with fresh lube.
3. In parking lot lock steering to the right, and then execute 5 Full Circles at (5-10 mph).
4. In parking lot lock steering to the left, and then execute 5 Full Circles at (5-10 mph).
5. Perform 4 Figure 8’s at (5-10 mph).
6. Freeway Speeds for 20 miles until operating temperature is achieved.
7. In parking lot lock steering to the right, and then execute 5 Full Circles at (5-10 mph).
8. In parking lot lock steering to the left, and then execute 5 Full Circles at (5-10 mph).
9. Perform 4 Figure 8’s at (5-10 mph).
10. Immediately drain current lube in axle and refill with fresh lube.
11. Perform Steps 3 thru 9 again.
12. Immediately drain current lube in axle and refill with fresh lube.
This procedure is only to be used for the condition listed above. During regular maintenance, the fluid only needs to be changed one time. The maintenance schedule can be found in the owner’s manual on pages 11-5 and 11-7. For regular service the fluid is changed at 45,000 miles or 72,000 Km and for severe service the fluid needs to be changed every 15,000 miles or 24,000 KM.
Oil Dextron LS Gear 75w90: US - 88862624 2.43 Qt.; Canada - 88862625 2.3L
Warranty Information
For vehicles repaired under warranty use:
Labor Operation
Description
Labor Time
F9744*
Road Test, Drain, and Refill Axle 3 Times
2.6 Hours
* This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2013 General Motors. All rights reserved.
Bottom of Form
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 07-24-2013, 06:21 PM   #2
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2013 ZL1 #2303
Yep that's the exact procedure that my dealer used with mine - they phoned me up before taking it out due to the amount of miles they were going to have to put on the car - wanted to make sure I was happy for them to do that.
I said yes, and the problem was fixed when I got it back
Modern07 is offline   Reply With Quote
Old 07-24-2013, 06:40 PM   #3
bumblebeecamaro
Car Lover By Nature
Drives: Mini Cooper S
subscribed - I might just do this myself instead of having the dealer do this. the thought of anyone but myself putting 20 miles on my car makes me cringe.
bumblebeecamaro is offline   Reply With Quote
Old 07-24-2013, 06:49 PM   #4
DrkPhx
DrkPhx's Avatar
Same here.
Old 07-24-2013, 06:54 PM   #5
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
Ridiculous the procedure used 1/4 tank of premium and puts 60 miles on car. I dont see the part says drive 20 miles in between each flush
joes407 is offline   Reply With Quote
Old 07-24-2013, 06:55 PM   #6
roSSco
∞ Smiles per mile
roSSco's Avatar
Drives: 2013 ZL1 Summit White A6
I have a constant moan at any speed over 35 mph while decelerating. I assume that it is due to improper lash or break in. I suspect it was during the 44 miles of test drives before I got the car, because I was very easy on it during break in.
What I am trying to say is, is there a chance that the procedure outlined above would be of any benefit to me? I realize I would have to do it since the bulletin does not address my complaint.
roSSco is offline   Reply With Quote
Old 07-24-2013, 07:10 PM   #7
joes407
joes407's Avatar
The procedure did not fix mine so it will be going back
Old 07-24-2013, 07:20 PM   #8
DJ-Silver 2SS
Ah DJ-IOM ZL1 haha
DJ-Silver 2SS's Avatar
Drives: 13 IOM ZL1 M6 & 10 SIM 2SS M6
Send a message via Yahoo to DJ-Silver 2SS
i had the procedure done as well.... not fixed so it is going back. I found out from the dealership, if the vehicle comes back a second time and still falls under the bulletin, then they can request a new center section and replace it.
2013 IOM ZL1 #002415 Born 09/13/12
2010 SIM 2SS/RS #005549 Born 05/02/09
DJ-Silver 2SS is offline   Reply With Quote
Old 07-24-2013, 07:22 PM   #9
joes407
joes407's Avatar
My dealer knows my car does not leave lot without me. They had me drive the car through the procedure with tech in passenger seat
Old 07-24-2013, 09:20 PM   #10
OldScoolCamaro
...way over the top technical, my head started spinning reading the service bulletin <as presented by the OP>....get it warm, drain the fluid...replace with correct fresh lubricant. Done deal.
Old 07-25-2013, 05:34 AM   #11
jtulery
Drives: 2012 CAMARO ZL1, 2012 CTS-V,
Got it hot change oil to Amsoil oil.
In parking lot lock steering to the right, and then execute 5 Full Circles.
In parking lot lock steering to the left, and then execute 5 Full Circles. Did it about 500 miles ago
working good !!
jtulery is offline   Reply With Quote
Old 07-25-2013, 06:06 AM   #12
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Drives: Zoe the ZL1, 2012 Frontier
Can anyone describe the sound etc tht causes you guys to take the cars in for the rear end problem?
Thanks.
FOR SALE: 2013 ZL1 Message me if interested
G-Oil Guy is offline   Reply With Quote
Old 07-25-2013, 07:03 AM   #13
ZL1 TIBS
ZL1 TIBS's Avatar
Drives: 1968 Camaro, 2012 ZL1
I think the real question is, will doing nothing cause damage to the rear. I think probably not. I hear it all the time when cold and to me it is just a normal high performance limited slip rear sound. It sounds like all the procedure is doing is wearing out the clutches.
Alan Tibbetts
Aston, PA
1968 Chevrolet Camaro LS-1/T56 transplant
2012 CRT 6 SP ZL-1
ZL1 TIBS is offline   Reply With Quote
Old 07-25-2013, 07:16 AM   #14
SSNIGHTMARE
SSNIGHTMARE's Avatar
Drives: 2002 SS Camaro
sounds like a good way for your dealer to do some donuts in your car
04 GMC LB7, SOCAL DIESEL STAGE 2 HEADS, CROWER RODS, TWIN CP3 483 RWHP, 1008 FT/LBS, ATS 5K
02 SS, LSX BLOCK, 500 HP, WAITING ON BOOST
98 COBRA, EAGLE CRANK AND RODS, 568 RWHP, S-TRIM
02 SS, STOCK, THE SLO HO
08 CTS, POS
EFI Live
"Nitrous is like a hot girl with STD's, you know you wanna hit it but you're afraid of the consequences!"
"..it does not require a majority to prevail, but rather an irate, tireless minority keen to set brush fires in people's minds.."
--Samuel Adams
SSNIGHTMARE is offline   Reply With Quote
