sjm autoprod
Old 07-24-2013, 09:09 PM   #1
Big C CamaroSS
Drives: Black Camaro 2SS/RS 1LE
Tightening the crank bolt to 140 degrees?
My mechanic friend and I got a great start on my Maggie supercharger and Kooks headers install today. We did however get stuck on the step after you drill the 2 holes in the crankshaft pulley and slide in the 2 little pins. You have to torque the bolt to 37lb ft of torque. Then the bolt has to be torqued 140 degrees. He bought the gadget to tell how many degrees the bolt has been turned so we aren't guessing. We have it turned/tightened to 70-75 degrees, but we're such a long way from 140 degrees like it says in the Magnuson manual and its getting VERY hard to turn the bar. To those that have installed a Magnuson TVS2300 supercharger, what did you do to get the pinned crankshaft bolt turned/tightened to 140 degrees?
Also, I have all 3 panels (under the dash, door sill, and rear side) off on the passenger side because of the MSDS fuel pump voltage booster install. Can we run the vacuum line along that side and go through the firewall to the supercharger? Is there a spot to put it through into the engine bay?
If we can get help with these two problems.....tomorrow should be very good and we will finish the supercharger!!
Big C CamaroSS is offline   Reply With Quote
Old 07-24-2013, 09:14 PM   #2
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Drives: 2011 Camaro RS/2SS (L99) Synergy
We could only get my crank bolt to around 80 or 90 degrees? We tried everything. We ended up calling it good enough. I can't imagine its going anywhere?
11syn3rgy is offline   Reply With Quote
Old 07-24-2013, 09:18 PM   #3
Big C CamaroSS
BTW we do know the bolt is torque to yield so we need to "stretch" it, but good God that thing is going to require some serious muscle to get it to 140 degrees
Old 07-24-2013, 09:21 PM   #4
Big C CamaroSS
Well I want to make sure that's OK. Ted warned me to follow the directions to a "T". But yeah you are correct.....that bolt ain't going no where!!!
How are you liking the supercharger 11syn3rgy? Mine is red too. It will look sweet on my black '13 1LE
Old 07-24-2013, 09:22 PM   #5
old motorhead
Drives: Maggie blown LS3 vette
Use an impact wrench. Mark the socket so you can see what you're doing.
old motorhead is offline   Reply With Quote
Old 07-24-2013, 09:29 PM   #6
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
We used an impact as well. Still no where near 140 degrees. My buddy has been a GM master mechanic for a long time. I'm not gonna lose any sleep over it
Old 07-24-2013, 09:31 PM   #7
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Love it!! I wasn't sure about the red blower with my Synergy Green, but I really like it. Just brought it out to the Car Craft show last weekend, and everyone really liked it. Good luck man!!
Old 07-24-2013, 09:42 PM   #8
Big C CamaroSS
Did you install an MSDS fuel pump voltage booster 11syn3rgy? If you did, where did you run the vacuum line through the firewall?
Old 07-24-2013, 09:56 PM   #9
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
I have it on my list of next mods but I haven't installed it yet. Sorry man. Once I pulley down to 3.6 and install my CAI, I will getting the MSD voltage booster. No need for it with my current set up. I'm sure one of the guys on here will be able to help?
Good luck!
Old 07-24-2013, 10:17 PM   #10
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
I just pulled mine up tight with an impact and called it good. Had it off 3 times and tightened it the same way every time and it's still on. Hard to hold the motor with the A6.
Nitroman28 is offline   Reply With Quote
Old 07-24-2013, 10:43 PM   #11
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 07-25-2013, 06:05 AM   #12
Big C CamaroSS
^^^ yeah I was told by my mechanic friend that the bolt is a use once and then garbage it bolt!!!
Old 07-25-2013, 06:50 AM   #13
The Stig
knows 2 facts about ducks
The Stig's Avatar
I really really hope you used a new bolt each time. A bolt is labeled as "Torque to Yield" just for kicks, there's a reason you are supposed to use a new bolt each time.
Click to view my build thread
Old 07-25-2013, 07:25 AM   #14
dan0617
dan0617's Avatar
..... Or go with an ARP bolt that isn't TYY.
