Old 07-25-2013, 01:28 AM   #1
ZL1 Spoked
ZL1 Spoked's Avatar
Drives: Camaro ZL1
IS THIS A GOOD DRAG SETUP?
Let me know guys! Also, if the wheels are no good or the offset too off, what do you suggest?
http://www.summitracing.com/parts/HOO-18157/
Hoosier Drag Racing Slicks 18157
Tire, Drag Slick, 28.00 x 10.00-17, Bias-Ply, Solid White Letters, D06 Compound, Each
Tire Size:28 x 10.00-17
Wheel Diameter:17 in.
Sidewall Style:Solid white letters
Tire Construction:Bias-ply
Tire Diameter:28.00 in.
Section Width:11.30 in.
Tread Width:9.50 in.
Minimum Recommended Wheel Width:8.00 in.
Maximum Recommended Wheel Width:10.00 in
Detroit Wheels Black Corvette ZR1 Wheels 841-7961B
http://www.summitracing.com/parts/tw...961b/overview/
Wheel, Corvette ZR1, Aluminum, Black, 17 in. x 9.5 in., 5 x 4.75 in. Bolt Circle, 7.50 in. Backspace, Each.
Wheel Width (in):9.500 in.
Wheel Material:Aluminum
Primary Wheel Color:Black
Wheel Finish:Gloss
Manufacturers Wheel Seriesetroit Wheels Corvette ZR1 Series
Backspacing (in):7.500 in.
Offset:+56.00mm
-2013 Camaro ZL1-Black Stripe Package-Ambient Light Kit-Subwoofer Package-Sunroof-Suede Package-NAV MYLINK-MANUAL BABY-Dual Vented Fenders-Exposed Carbon Fiber Insert
-Black 10 Spoke Wheels
604 RWHP 602 LBS/TQ
ZL1 Spoked is offline   Reply With Quote
Old 07-25-2013, 03:25 AM   #2
The Baron
The Baron's Avatar
Drives: 2013 zl1
Iv ran this tire (see the car in sig). But unless you are either a 6 speed deep in the 11s or a auto in the bottom 10s Its extreme..
2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44
2007 corvette vert ..retired..
2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far..
The Baron is offline   Reply With Quote
Old 07-25-2013, 04:02 AM   #3
ZL1 Spoked
ZL1 Spoked's Avatar
Drives: Camaro ZL1
I manage to hit high 11s on the stock tires, by extreme you mean what exactly? Thanks for the help
604 RWHP 602 LBS/TQ
Old 07-25-2013, 06:24 AM   #4
cam99
cam99's Avatar
Drives: 2012 ZL1
didn't think 17's would fit on the rear on the zl1
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 07-25-2013, 06:42 AM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
It would depend on the offsets, as the rear Brembos are the same.
Click to view my build thread
Old 07-25-2013, 07:35 AM   #6
All-American ZL1
Chevy Power
All-American ZL1's Avatar
Drives: 13 ZL1 M6 #123, '98 Jeep Wrangler
Most people would also suggest skinnies in front when you've got slicks on the back. Just something else to think about if you're considering radials vs slicks
2013 #123, M6 2.38 upper, ID850, dynatech 1 7/8 headers, cats, X pipe, ADM CAI, 160 Tstat, Hurst line lock, tune by FSP
Sebring 2:39.20 MPSS
All-American ZL1 is offline   Reply With Quote
Old 07-25-2013, 02:18 PM   #7
ZL1 Spoked
ZL1 Spoked's Avatar
Drives: Camaro ZL1
ZL1 rears are 45 offset I believe ? and these corvette 17s are 56mm
604 RWHP 602 LBS/TQ
Old 07-25-2013, 02:23 PM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I believe you'll need a spacer to run those rims, or V6 brakes. Or you could get a set of Bogarts, Welds or Racestars which I think all work with stock brakes.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
