Old 07-25-2013, 12:33 PM   #1
wkid1le
Drives: 2014 2SS 1LE
Secure full size spare tire in trunk
Does anyone have suggestions for securing a full size spare tire in a 2SS trunk so its held tightly in place?
wkid1le is offline   Reply With Quote
Old 07-25-2013, 12:36 PM   #2
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
Duct tape.
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller
Aesthetic Mods
Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items
snymat68 is offline   Reply With Quote
Old 07-25-2013, 12:45 PM   #3
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
Does it even fit inside the tub?
JR 1 is offline   Reply With Quote
Old 07-25-2013, 12:58 PM   #4
Jcm
Drives: 2011 ss
In the trunk ,yes
In the tub ,,No
Jcm is offline   Reply With Quote
Old 07-25-2013, 01:04 PM   #5
mdrobtx
mdrobtx's Avatar
Drives: 2010 2SS/RS Victory Red
I got the rubber mat. Helps keep it from sliding around.
21 years of owning Camaros. Finally got a 5th Generation.
1968 Coupe and 1967 Vert
mdrobtx is offline   Reply With Quote
Old 07-25-2013, 01:27 PM   #6
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
What about making up a bracket that bolt's on top of the wheel well cover, the wheel well is held in place with the large spinner cup nut so I feel it would hold the wheel safely in place. Sorry for the poor explanation.
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 07-25-2013, 03:16 PM   #7
2SS 2011
2SS 2011's Avatar
Drives: 2011 Camaro 2SS/RS M6 Black
Originally Posted by Jcm View Post
In the trunk ,yes
In the tub ,,No
Thats wrong.. I have the spare tire setup for the ss.. and the guy has the whole kit.. the rim and tire and jack fit securley in the tub part.. just take the foam rim outlay out and secure the kit..
2SS 2011 is offline   Reply With Quote
Old 07-25-2013, 03:58 PM   #8
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Read it again, he is asking about a full size spare, not the kit with the little donut tire....
So Cal Camaro is offline   Reply With Quote
Old 07-25-2013, 03:58 PM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Unless i'm mistaken, the spare kit doesn't have a FULL sized tire. The tub won't fit a OEM height tire in it or people would be putting one in there.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-25-2013, 04:23 PM   #10
DARK AGE 53
Drives: 2010 SS
Just wondering if you're going to have a front or rear tire in the trunk?
Old 07-25-2013, 06:06 PM   #11
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
I used a front wheel and a 245/35/20 and it fits the wheel well perfect. I knocked the stud out of the hold down bracket and put a longer bolt thru it long enough to go thru the center of the wheel( m10 x 1.50 thread) then just put the board/cover back over it and used the oe plastic round hold down to hold all of it down.. looks perfect oe just about 3inches higher.
JantzenOKC is offline   Reply With Quote
Old 07-25-2013, 08:51 PM   #12
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
I just use a tie down strap similar to the pic. Looped around the tire and wheel pulled tight and connected to one of the rear lower steel anchor hooks. Holds good. I got the scissors jack and other tools stored in a case on the other side of the trunk.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 07-26-2013, 01:14 AM   #13
Brianstanley
Brianstanley's Avatar
Drives: 2012 2LT RS Coupe in CRT
I just have to ask, why a full size spare tire? Are you doing a major cross country road trip? OK, then I understand. But if is the daily driving around town, then think how many times have you have had a flat tire and been in jam while at home? Do you really want to carry the added weight around all the time?
Brianstanley is offline   Reply With Quote
Old 07-26-2013, 06:16 AM   #14
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
GM actually sells a strap for securing the flat tire in the trunk once you change it out. There are metal tabs like for a child seat in the trunk that it secures to. I got mine from GM parts direct #25892541 $13.50
MMC is offline   Reply With Quote
