Old 07-26-2013, 02:50 PM   #1
godfather323
godfather323's Avatar
Drives: 2010 Camaro RS- Red Jewel Tint-
steering wheel shaking after spacers...
I just put my stock rims back on and wanted to make them look flush... so i put 5x120 hub adapters on stock r/s wheels... they're 25mm spacers all around. I hand tightened every lug nut and torqued it myself properly. (At first used a gun, then thought that might be the issue but same thing happened after i hand torqued slowly.) I know these hub adapters are not hub centric... Is that what is causing the issue or is it maybe that I need an alignment or wheel rebalanced?
Steering wheel starts shaking around 45mph...
if anyone can help me out here that would be greatly appreciated.
Godfather
godfather323 is offline   Reply With Quote
Old 07-26-2013, 02:52 PM   #2
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
If you've got rust or debris between the spacer and the hub, then that can cause vibrations. 99% of the time that's the case, but if the spacer isn't a quality spacer, that can cause issues as well. What kind of spacer are you using??
ModBargains.com is offline   Reply With Quote
Old 07-26-2013, 03:03 PM   #3
godfather323
im not sure what brand spacers they are(not too savy with these things lol)... but i know there good quality stuff because my buddy ran these for a while now and they have no vibration on his cars...
Godfather
Old 07-26-2013, 03:04 PM   #4
SabotAndHeat
SabotAndHeat's Avatar
Drives: 2010 Camaro
Danger Will Robinson!
It is definately because they are not hub centric! Never skimp where the rubber meets the road, so to speak.
I have Eibach hubcentrics. They are sweet!
But, in all seriousness...stop driving with those on your car immediately! You can have a serious malfunction that occurs at hi-speeds and next thing you know you've bought the farm...and maybe taken others with you.
SabotAndHeat is offline   Reply With Quote
Old 07-26-2013, 03:24 PM   #5
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
^ what he said. Get some hub centric spacers and you should be fine.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 07-26-2013, 03:45 PM   #6
godfather323
first thing i do when i get home is take these off.
Godfather
Old 07-26-2013, 04:00 PM   #7
godfather323
anyone have recommendations on what spacers i should get... im looking for 25mm hub adapters all around... i dont know what the offset is or what size to buy to ensure its hubcentric.
Godfather
Old 07-26-2013, 04:51 PM   #8
QUICKSS
Drives: 2013 2SS
I put quarter inch spacers on my Dodge Ram. Big mistake. Shortly after I had noise and shaking and before I knew it I broke 4 lugs off right before getting on the highway.
QUICKSS is offline   Reply With Quote
Old 07-26-2013, 05:19 PM   #9
Outlaw77
Outlaw77's Avatar
Drives: 2010 2SS/RS I.O.M. Camaro 6MT
H&R or Eibach are the only ones I would recommend.
2010 Cammed & Blown Inferno Orange 2SS/RS LS3 6M
Maggie TVS 2300 8 psi/1:1 overdrive cogs/3.6 pulley/LPE GT-14 cam/BTR valve train kit/KB BAP/LPE ZR1 65lbs injectors/NGK TR71X plugs/Roto Fab CAI/Kooks LT's & cat deletes/Magnaflow x-pipe & mufflers/BMR springs/carbon fibre stripes/20% tint
Cam specs: 223/235 duration @ .050 lift - .610/.620 115.0 C
640 rwhp 603 rwtq
Built and Dyno Tuned by Davenport Motorsports
Wheels: Rohana RC7 Matte Graphite 20x10, 20x11 Super Deep Concave + 275/40, 315/35 Nitto NT05
Outlaw77 is offline   Reply With Quote
Old 07-26-2013, 06:51 PM   #10
2010SSRSM6
2010SSRSM6's Avatar
A buddy is running the 25mm Eibach's and hasn't had an issue. He is north of 700hp and drives like an ass so you should be good with them. I've never heard anything bad about H & R either.
Old 07-30-2013, 01:04 PM   #11
SabotAndHeat
Drives: 2010 Camaro
I ended up going 25mm Eibachs in the front and 22mm Eibachs in the rear. Flushed out both front and backs to the wheel well, but still left rears just a tad wider.
Old 07-30-2013, 02:35 PM   #12
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
5 x 120, 66.9 center bore.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
