Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 07-26-2013, 10:55 PM   #1
intensifi
Drives: '12 2LT Convertible
SS slotted rotors advise appreciated
Which manufacturers should I be looking at?
Suggested vendors would be appreciated as well.
I'm about to install SS Brembos on my 2LT. I'm trying to decide if I should use the stock SS rotors or upgrade the rotors as part of the install.
Mods: GM Locking Gas Cap, RS License Plate Frame
intensifi is offline   Reply With Quote
Old 07-26-2013, 11:10 PM   #2
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
With modern pad compounds, there is really no need to run slotted rotors or drilled either, unless you just want the racey look.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 07-26-2013, 11:37 PM   #3
intensifi
I was under the impression that the slotted rotors stopped better. They seem to on my '01 X5.
Old 07-26-2013, 11:41 PM   #4
nbrigdan
Drives: '12 S550, '10 WRX, '13 SS
RacingBrake has good quality from what I've heard, I believe some people on this forum have had good experience with them. (Rotors)
"From ABS shudder that came on surprisingly early in the lousy brake pedal's travel to a looser rear end than Kim Kardashian"
nbrigdan is offline   Reply With Quote
Old 07-27-2013, 12:49 AM   #5
SSMickey
SECC
SSMickey's Avatar
There is a lot of misinformation floating around about brakes. Heck, most people you ask think the brakes stop the car. They don't.
http://www.camaro5.com/forums/showth...401&highlight=
See post 21. Pete tracks his car HARD and has seen no need for slotted or drilled rotors. Save your money and put it towards something with a little bit more return for the investment.
Old 07-27-2013, 12:53 AM   #6
JewelSS
Norcal Camaros
JewelSS's Avatar
Drives: 2010 Red Jewel 2SS L99
Agreed ^^^ if its looks ur after then do it but not much advantage to it.
Fire Extinguisher, AAC footwell lighting, Switchback LED's, AAC Mailslot scanner, AAC Plasma fogs, Eagle eye HIDs, RJT Painted calipers, Custom painted engine bay, RJT Front splitter, Viteese Paddle Shifters, CFD Hurst style Shifter, RJT painted speedo & gauge trim, RotoFab CAI, XS Power 2" Headers with full 3" exhaust, Granatelli Slotted rotors with Hawk HPS pads, BMR lowering Springs, BMR Strut tower brace, Custom HP Tune by Mark Romans
JewelSS is offline   Reply With Quote
Old 07-27-2013, 03:44 AM   #7
SPCBA
Blake
SPCBA's Avatar
Drives: pleather and Chiclets
there is advantages in rotors that can dump
heat and are designed to take abuse and run cooler than other rotors.
racingbrake is the top of line stuff. gurantee my brakes run cooler than other leading brands. the veins and directional heat dissipation is a big reason racing brake 2 piece rotors run cooler and are now on their 10th track day with them.
SPCBA is offline   Reply With Quote
Old 07-27-2013, 04:49 AM   #8
CHMSC
ZOMBIE KILLER!!!!
CHMSC's Avatar
Drives: 2012 SS/RS LS3
X 1,000 racing brake rotors will be my next purchase. I didn't think rotors could make a huge difference till I rode in a car with them on a road course. These rotors matched with their brake pads are freaking rock stars!!!!
CHMSC is online now   Reply With Quote
Old 07-27-2013, 06:58 AM   #9
Stubbsy
Drives: 2012 SS RS
I fitted a set from R1 Concepts they were about $500 USD from memory,they look great and my SS stops on a dime. I don't know why my photo is upside down, may be coz I'm from the land down under.
Stubbsy is offline   Reply With Quote
Old 07-27-2013, 07:31 AM   #10
Apex Chase
Apex Chase's Avatar
Drives: 2000 Camaro SS
RacingBrake rotors are amazing. If you need "the best", then they are what you want to be looking at. But honestly, they are overkill for most people.
Apex Chase is offline   Reply With Quote
Old 07-27-2013, 08:35 AM   #11
intensifi
Thanks for the info so far!
It sounds like racing brake and R1 (slotted & drilled) are way out ahead of what I need for this car though.
I also appreciate the information that stock is sufficient. This is obviously worth consideration.
How about I add a few other desires?:
1) lighter weight
2) doesn't rust when washed
3) not made in china
Old 07-27-2013, 08:37 AM   #12
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
What are your driving/performance goals? If you're planning on taking the car to the track, then RacingBrake rotors make a world of difference not only in fade-free stopping power because they run cooler under hard braking conditions, but also in just about every other area of performance because they're about 6 lbs lighter each than the stock rotors. Removing unsprung rotating weight (i.e. wheels, tires, brake rotors) is the most important and performance-improving weight to remove.
If you're not planning on going to the track then the stock SS brakes are more than good for the street.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 07-27-2013, 10:53 AM   #13
Team STILLEN
Team STILLEN's Avatar
Drives: 10 Camaro, 10 GT500, 09 GT-R, etc
We have some really good prices on our Stillen Sport Rotors!
The are made in the USA and machined by us in house!
http://www.camaro5.com/forums/showthread.php?t=257770
PM or Call me directly with any questions.
Thanks
JT
JT - STILLEN Performance Specialist
jtang@stillen.com | 714-540-5566 ext 174
Authorized Dealer - Hotchkis | KW | Eibach | JBA | Magnaflow | Stainless Works | Kooks | CAI | Roto-Fab | K&N | Airaid | AEM | AP Racing | Hawk | Magnuson | Whipple | Edelbrock | Vortech | Procharger | RKSport | Seibon | ACT | T-Rex | Street Scene | WeatherTech
Team STILLEN is offline   Reply With Quote
Old 07-27-2013, 10:38 PM   #14
t&t moyer
It's all hers.
t&t moyer's Avatar
Drives: 13' SS/RS 1LE / 09' Hayabusa
OP, you have a budget in mind?
Ordered: 2/14/2013 Delivered: 3/21/2013
t&t moyer is offline   Reply With Quote
Old 07-28-2013, 12:05 AM   #15
intensifi
Hundreds not thousands
Old 07-28-2013, 12:43 AM   #16
t&t moyer
It's all hers.
t&t moyer's Avatar
If you want to go for esthetics / looks maybe look at the Granatelli dimpled & slotted rotors. I ordered a set to try. As much as I wanted to go with the 2-pc RB RacingBrake rotors I just couldn't justify it. If I'm not happy with the Granatelli rotors I'll look at Brembo.
Old 07-28-2013, 02:05 AM   #17
nbrigdan
Just get front Racing Brake Rotors, and plus if you actually want to stop in a shorter distance you're gonna need stickier tires, but the advantage with this is your brakes are never going to overheat and go mushy
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
