Gen5DIY
Old 07-27-2013, 01:44 PM   #1
BiG_TiMe
BiG_TiMe's Avatar
Drives: idk
Any tips on installing coilovers?
So I plan on installing my Megan Coilovers on Monday with some friends and I was wondering if there were any tips I should know before the install
BiG_TiMe is offline   Reply With Quote
Old 07-27-2013, 02:22 PM   #2
Synner
Drives: not stock
Have star bits for upper strut studs and beer for you. Its easy.
Old 07-27-2013, 02:24 PM   #3
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Sorry I can't offer any tips but could you post your impressions on them when you're done?
Old 07-27-2013, 02:34 PM   #4
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Best advice. It fairly simple if you have a problem chime back. On the rear if you dont drill the trunk. Preset them. Other than that took 3 hr with jack and jack stands. And a few drinks in between each one.
sent form my mini computer note 2
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 07-27-2013, 06:01 PM   #5
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
If you don't have the "proper" tools (spring compressor) and have access to air tools and you aren't worried about reusing the stock parts: once they are out of the car, wrap the coilover TIGHTLY with a towel making sure to cover the top as well. then just zip off the nut. The towel will keep the parts from shooting apart.
On the rear removal & install... disconntect the lower control arm from the spindle (both sides), have a ratchet wrench (15mm) for the inside forward most bolt holding the top on.
Also, as you drop the rear coilovers, turn them 90* and they come right out.
On the install for the rears, install the 4 bolts just enough to hold the coilover (do both sides before proceeding to the rest of the rear install), then position them in the lower control arm, do both sides then install bolts, then attach to spindle, then tight everything.
ON REASSEMBLY, NO AIRTOOLS ON THE ENDS OF THE COILOVER MONOTUBES.
If I think of anything else, I will let you know. Intersted as to your opion of those as well.
R.I.P. http://www.camaro5.com/forums/showthread.php?t=373249
Back Street Performance has done a great job with ALL my Performance & Suspension mods, highly recommend them (Rich@BSP) he's in my friends list. https://youtu.be/Lht8sKe1Maw
TLSTWIN is offline   Reply With Quote
Old 07-29-2013, 02:46 PM   #6
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
http://www.camaro5.com/forums/showthread.php?t=221950
jeremywes is offline   Reply With Quote
Old 07-29-2013, 02:50 PM   #7
jeremywes
jeremywes's Avatar
The instructions say "Zero Preload". if you put 5-10mils of preload into the spring it will be very bouncy and you'll have to run them at full dampening to control it. They ride pretty well at zero preload, 36 psi (cold tire inflation) and somewhere in the 8-10 dampening settings. Good luck
Old 07-29-2013, 07:56 PM   #8
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Well?
Old 08-01-2013, 01:31 AM   #9
BiG_TiMe
BiG_TiMe's Avatar
Drives: idk
never got a chance to do it lol. they're still sitting in the box. hopefully within the next few days. but i'll definitely pass these tips to my friend who's gonna help me do it
