Old 07-27-2013, 08:07 PM   #1
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
18x9.5 40mm offset on the front
I bought a set of matching fronts for my car, 18x9.5 ZR1 replicas, 40mm offset.
Rears, just tied e brake cable back, 305/45R 18 Nitto NT05Rs:
I have Nitto 265/50/18's on the rims for the front
Did some work to fit them:
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-27-2013, 08:15 PM   #2
Pro Stock John
Writer
Ground this down info from a sux2bu thread:
But the tire rubs strut
I think 5mm spacer might be enough just ordered it
So there you have it. I've seen one other guy run the ZR1/Z06 fronts, JacFab, I don't know what tires he had up front. But for this combo, can get the wheel to work, but the tires I have rub the strut assembly. I will try 5mm spacer, and if that's still tight I'll go 8mm and pay $70 from that place that custom makes them. I ordered some for $33 with free shipping (5mm).
PROJECT HEAVY CHEVY
Old 07-28-2013, 11:27 AM   #3
Pro Stock John
Writer
I'm going to put some painters tape on the strut after I try the spacer. As I'll have 2 5mm spacers, I'll try one and if it's still scuffing I'll look at doing 10mm but I think 5mm might be enough I didn't hear them rubbing.
PROJECT HEAVY CHEVY
Old 07-28-2013, 12:11 PM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
It would have been a lot easier to pull the pads out, put them in a vice and cut the weights off there. That way you wouldn't have nicked the calipers.
Did you get a weight on the wheels or tires?
SUX2BU is offline   Reply With Quote
Old 07-28-2013, 03:53 PM   #5
Pro Stock John
Writer
Yeah I'd like to powdercoat the calipers anyway, maybe this will push me.
I can go outside and weigh a wheel + tire, brb.
PROJECT HEAVY CHEVY
Old 07-28-2013, 04:01 PM   #6
Pro Stock John
Writer
I'm getting 57.8 Juan.
PROJECT HEAVY CHEVY
Old 07-28-2013, 05:41 PM   #7
Jason@
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@ Send a message via MSN to Jason@
Posted in the Free Wheel Offsets thread. Those are going to look slick once you get them on there.
Jason@ is offline   Reply With Quote
Old 07-28-2013, 09:37 PM   #8
Pro Stock John
Writer
Thanks, they are tasty:
Jason, the spacers: http://www.ebay.com/itm/231018011293...84.m1439.l2649
I don't understand the toe out adjustment you said, never done that before. To answer your question, the tire and rim are not perfectly flush I can measure if you like. But the tire is not mega wider.
PROJECT HEAVY CHEVY
Old 07-29-2013, 12:56 PM   #9
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Ughhh John. You know your business partner happens to be very good at Camaro offsets and information, right?
Friends don't let friends hack their cars up or run spacers. I have failed you.
Tony
Fquick.com/NineBall
Old 07-29-2013, 01:31 PM   #10
Pro Stock John
Writer
I like how the ZR1 wheels look but running a little spacer was not my plan. We'll see how this goes.
PROJECT HEAVY CHEVY
Old 07-29-2013, 01:57 PM   #11
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
So no spacers needed for the rear then? I smell my possible rear drag setup...where did you get them?(sorry if I missed it)
2010 Camaro 2SS/RS LS3
959/869
416, AGP 6262, E85, Cam
Built by Mayhem Motorsports in Raleigh, NC
blake2010ss is offline   Reply With Quote
Old 07-29-2013, 02:02 PM   #12
Pro Stock John
Writer
No spacer in back, but you have to tie back the e-brake cable or it might rub on the edge of the wheel.
PROJECT HEAVY CHEVY
Old 07-29-2013, 02:17 PM   #13
blake2010ss
I got mine tied back already from a little rub.
959/869
Old 07-29-2013, 02:31 PM   #14
Nine Ball
Nine Ball's Avatar
27-30 range would have been a better front offset. You'll likely need a 10mm spacer to make them not look silly and tucked too far into the car.
Fquick.com/NineBall
