HeadlightArmor
Old 07-27-2013, 08:21 PM   #1
Airmaster
Go Gators!
Airmaster's Avatar
Drives: '13 Camaro '12 Abarth '97 Wrangler
Question So what's next?
I now have intake, exhaust, high flow cats, short shifter, light weight rims, performance tires, ported throttle body, and catch can.
What else is there performance wise for the LFX besides a tune or FI?
I've tossed the idea of the under-drive pulley around my head as well but other than that I think I'm out of bolt-ons....
Airmaster is offline   Reply With Quote
Old 07-27-2013, 08:59 PM   #2
markkk
markkk's Avatar
Drives: 2012 Camaro 1LS
ported heads? or what about upping your gear ratio?
markkk is offline   Reply With Quote
Old 07-29-2013, 04:53 PM   #3
Airmaster
Go Gators!
Airmaster's Avatar
How pricey are gears? Can I do the ports myself with a dremel?
Old 07-29-2013, 04:59 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
An Apex scoop will compliment your intake upgrades nicely.
Old 07-29-2013, 09:57 PM   #5
Airmaster
Go Gators!
Airmaster's Avatar
Are there proven gains on that? I think I'd be fearful of the extra dust and sand that would be thrown directly into the intake :/
Old 07-29-2013, 11:13 PM   #6
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
If you're not looking into entering the FI world than a good tune would compliment your mods nicely.
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 07-30-2013, 03:47 PM   #7
Buschman
Buschman's Avatar
Drives: 2015 1SS 1LE
Go with Chase, the scoop will help. The cost is really not much. I going to get mine next then work on the exterior more. I'm trying to stay away from a tune until I am out of warranty tho.
Just my opinion on gears, if your not regularly drag racing I don't see a reason. I am very happy with the stock setup myself. Could use some more off the line but you get that with the V6 and low torque.
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 07-30-2013, 04:02 PM   #8
markkk
markkk's Avatar
I'm not sure what the pricing is, but I would definitely have the porting done by a professional or at least someone with experience
Old 07-30-2013, 06:45 PM   #9
Apex Motorsports
Absolutely. It is proven on the dyno and at the track. You have nothing to worry about with dust, sand, or water.
Old 07-31-2013, 03:14 AM   #10
Hollywood323
Drives: 2013 Camaro 1LT/RS
Are they effective on the Injen CAI or there only for short rams?
Hollywood323 is offline   Reply With Quote
Old 07-31-2013, 06:45 AM   #11
Buschman
Buschman's Avatar
I would be semi concerned with hydrolock with the scoop on the Injen. Might be fine with the cover on it.
2015 1SS 1LE
Stock...ish
Old 08-06-2013, 01:16 AM   #12
TwentyTen2SSRS
TwentyTen2SSRS's Avatar
Drives: 2010 2SS/RS
Is the scoop specific for a certain CAI? I always see it combined with the CAI Brand CAI ?
Sent from my iPhone using Tapatalk 2
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
TwentyTen2SSRS is offline   Reply With Quote
Old 08-06-2013, 07:17 AM   #13
LS3 Handler
I love the LS3
LS3 Handler's Avatar
Drives: 2010 IOM 2SS Manual
I have the scoop on mine its works perfectly with my CAI brand cai. As your driving down the road it fills the cavity where the cai gets it air, with the cooler air from in front of the car. The only minus is you have to remove your stock Windsheild Washer bottle and unless you buy the new bottle for use with a scoop you wont have W/W. There is a guy up here thats is trying out a intake maniflod spacer to see if it will have a performance gain but other than a good tune, nitrous, cams/head work or FI it sounds like your performance mods are done.
Last edited by LS3 Handler; 08-06-2013 at 07:19 AM. Reason: If your cai pulls its air from the front cavity behind the driver side front bumper the scoop would help any brand cai.
LS3 Handler is offline   Reply With Quote
