JDP Motorsports
Old 07-27-2013, 07:27 PM   #1
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Finally pedderized. Now an interesting problem
Took me twice as long as it should have, but I'm finally done with the xa coilovers, zl1 conversion sway bars, and a few bushings. I would take some pictures but.... I'm stuck in my garage. There is a hump to get down to the parking lot. I thought I would have clearance with the header clamps but I don't. It's not a super aggressive drop. 660mm. Time to pick up some 4x6's and build a ramp. I may get some pics up by tomorrow afternoon.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 07-27-2013, 09:44 PM   #2
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
rockrau is offline   Reply With Quote
Old 07-28-2013, 01:09 PM   #3
Denis
Denis's Avatar
Drives: 2010 SS
Haha. Not the worst problem to have. I mean its a problem but not as bad of an issue as I was expecting to read about lol
Old 07-28-2013, 03:17 PM   #4
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Alright. I got it out the garage to take for a test drive and some pictures. Couldn't really hammer it because I notices some clunking from the rear end and lower speeds over small bumps. Higher speeds and larger jolts I couldn't hear it. I rechecked all bolts that attach to the lower control arm 2 times. I'm not really sure what could be making the noise. I suspected the drop links, but they are on there pretty tight. No play at all. I may need to head over to ADM and get my gears and sub frame bushing put on earlier than expected while they look at my mess that I did.
It looks great however. I have it set to 660MM. I didn't want to go too low.
Old 07-28-2013, 04:04 PM   #5
Denis
Denis's Avatar
Drives: 2010 SS
Wow. Looks awesome.
Old 07-28-2013, 04:35 PM   #6
rockrau
rockrau's Avatar
Welcome to the Pedders Nation!
Old 07-29-2013, 08:49 AM   #7
JusticePete
Wrote the 5th Gen Book
JusticePete's Avatar
Drives: Camaro Justice
If you'll be at the FEST we can trouble shoot the noise at Bruce Raymond's.
Old 07-29-2013, 09:21 AM   #8
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
I really wish I could. They need to have a fest in TX!
Old 07-29-2013, 09:44 AM   #9
JusticePete
Ok.
1. Double check all the bolts in the rear.
2. With the tighter suspension, exhaust noise can occur that wasn't present with the softer OE setup. Look for any possible points of conact and adjust as necessary.
3. Pull the rear struts and verify the assembly stack is in order.
Old 07-29-2013, 10:20 AM   #10
Raptor3141
Raptor3141's Avatar
Drives: 2010 2SS/RS RJT M6
Did you remember to clock the bushings? I noticed the same type of clunking sounds in the way to the alignment shop. Completely cleared up after clocking.
Raptor3141 is offline   Reply With Quote
Old 07-29-2013, 10:38 AM   #11
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
I haven't got it aligned yet. I may do that, but I would hate for that not be it and have to disassemble just to have to realign.
Old 07-29-2013, 01:35 PM   #12
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
Tru dat!
jeremywes is offline   Reply With Quote
Old 07-29-2013, 03:36 PM   #13
caverman
caverman's Avatar
Drives: '69 SS Convertible
You shouldn't have to disassemble anything for the alignment. Hopefully you have some Pedders rear camber bolts though. They make a big difference in alignment for a lowered car. I was skeptical that they would really help at first but now that I have them and have had my car aligned I'm a believer.
You should still "time" your bushings. If you've done some the trailing arms along with your LCA then you've already done some of this but you will probably need to go in and do the front.
BTW: I use a guy up in Denton that does a pretty good job and he's cheap as well. Normally only $70 for an alignment. Last time I had him install my camber bolts as well and he only charged me another $20 ($90 out the door) and him almost got it perfect to the Pedders Aggressive Street specs. PM me if you want his info.
Build Journal
Old 07-29-2013, 04:34 PM   #14
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
I do have the camber bolts. This sound is metal to metal like. I may time the lca bushing and lower strut bushing tomorrow. That's about all I can get to before an alignment.
